It is currently Wed May 27, 2026 5:04 pm
 Post subject: 1977 no air blowing
PostPosted: Sun Mar 27, 2011 11:27 pm
Hey guys,
just picked up a 77 luv and can't get any thing to blow out the vents,floor or defrost. the ac is not hooked up but that shouldn't stop the vent or heater from blowing right? any help would be greatly appreciated thanks
 Post subject: Re: 1977 no air blowing
PostPosted: Fri Apr 01, 2011 9:07 pm
Can you hear the blower motor operating or when you turn on the switch does nothing happen? Need a bit more info. If the motor is operating check your control valve for operation... heat/cool, floor/defrost, (whatever the terminology is for the control valve) but regardless if the motor is working you should feel air if the ducts are connected.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Apr 02, 2011 3:58 pm
When I slide the switch nothing happens at all I'm hoping the switch is bad or disconnected but does anyone no how much a blower motor costs and if it is available
PostPosted: Sat Apr 02, 2011 4:39 pm
Before you start replacing switches and motors check fuses, if they are good check the connections of the fuse box and the rivets of the fuse box mounts to make sure they aren't corroded. Check wiring to make sure nothing is cut, pinched, broken, loose or anything else. THere are all kinds of electrical gremilins with these rigs. If you have a test light check for power at the switch and if you have it check for power at the motor with the switch on. As far as finding parts, check the parts stores...they do still have alot of parts for these rigs and also check for isuzu of a close year. Some parts interchange.
1981 Luv 2WD
1981 Luv parts trk
Users browsing this forum: Google [Bot] and 64 guests
