It is currently Sun Jun 07, 2026 7:31 pm
 Post subject: timing chain change
PostPosted: Tue Mar 08, 2011 12:28 pm
do you really need to pull the motor to change the timing chain? how about a ball park price for having it changed,81 luv automatic
 Post subject: Re: timing chain change
PostPosted: Thu Mar 10, 2011 12:14 am
you don't HAVE to, but it makes things so much easier...
PostPosted: Thu Mar 10, 2011 1:07 am
do you need to pull the head as well? i am going to get a manual but i know they tell you the RIGHT way to do things
PostPosted: Thu Mar 10, 2011 8:05 am
There are two bolts that go through the head into the front timing cover, which means the front cover is tight to the head and probably has sealant at the juncture to the block. The head gasket may even extend out over the front cover, it's been too long since I looked. IMO-If you don't remove the head you'll never get the cover out and back in.
