It is currently Thu Jun 25, 2026 10:25 pm
 Post subject: trottle question
PostPosted: Thu Jul 29, 2010 10:11 pm
I have a 78 Bone stock and my throttle sticks a little so therefore it idles fast which i dont like lol but ive checked its not the cable its the linkage it moves on the rod its bolted to. If i pull on the linkage mannualy it goes back to normal, i just dont know how to make it solid to where it doesnt move on the rod or if anyone has had this problem before and how to fix it.
I Dont Need Sex Life Fucks Me Whenever It Can.
 Post subject: Re: trottle question
PostPosted: Fri Jul 30, 2010 6:11 am
Sounds like it is old and the hole is worn too big. Replacing the rod and linkage would be the best fix if you coul dfindor even make new ones. I have know people to put Locktite on worn linkages. It won't stick to oily metal, but take up the slack.
PostPosted: Fri Jul 30, 2010 9:08 pm
Is their a spring for throttle return? Might try replacing it with a stronger spring.
PostPosted: Mon Aug 02, 2010 4:57 pm
yea a stronger spring would prally work...
PostPosted: Mon Aug 09, 2010 11:57 pm
put a stronger spring on there and still dosent go to regular idle ... i hate my carb.... ive learned carburetor is german for dont fuck with it :o
PostPosted: Wed Aug 11, 2010 10:21 am
Check the choke pull off and all of the vacuum lines.Spray carb cleaner at the base of the carb to find a leak.If RPMs change you have a vacuum leak.Also might want to check if idle solenoid needle is sticking.
PostPosted: Mon Dec 27, 2010 10:46 pm
well i finally found out what was making it stick. my choke was too far open or closed (im not really sure) and the throttle was getting stuck on the back side of the choke lever thingymajig
Users browsing this forum: No registered users and 54 guests
