PostPosted: Thu Aug 26, 2010 9:58 pm
Guys
What size plugs do you use for the air tubes?Whoever removed the smog pump on my truck just bent the pipes after cutting them and they are leaking. I would like to find ones with Allen heads on them so I can turn them down flush.
And yes my carb is being rebuilt right now so I can get it back on the road...Hopefully done Monday!
PostPosted: Fri Aug 27, 2010 6:01 am
Really good solutions are hard to find. It is an unusual thread, 14mm-1.0 if I remember. The thread is used on spark plugs and some wheel studs. You might try someplace such as Fastenal or McMaster-Carr.
PostPosted: Fri Aug 27, 2010 6:25 am
I was searching for a thread and found out they are 4 by 1.25 and someone used oil drain plugs.I think I am going to try that! Thanks though.
PostPosted: Fri Aug 27, 2010 7:53 am
Forgot about clearance for the valve cover.Going to an implement dealer and looking for the metric plugs!
PostPosted: Fri Aug 27, 2010 9:01 am
I found these on feebay and they work perfectly. Had them in 3 days and they were half they price of local parts stores even with shipping.
http://cgi.ebay.com/5-pcs-1-4-Steel-Hex ... ltDomain_0
1990 Chevy Suburban
PostPosted: Fri Aug 27, 2010 9:55 am
Any hardware store will have 1/4'' pipe plugs cheap, but they aren't the right size. You may be able to jam them in, but they aren't right. I found an old spark plug. It is a 14 mm 1.25 thread, a finer thread than 1/4'' pipe.
PostPosted: Fri Aug 27, 2010 10:39 pm
I am going to see if I can find the right pitch Allen head bolt.But it is being a bitch. I hate cobbling crap together.It usually leaks(like mine is now) looks bad and like mine cuts yo while you are working!
PostPosted: Fri Aug 27, 2010 11:14 pm
Take the threaded portion that goes into the head, remove the tubes, tap the inside for a hex bolt (or set screw), thread them back into the head- did that 30 years ago, never a leak, & it's cheap, the bolts can be SAE thread, whatever size best fits.
PostPosted: Fri Aug 27, 2010 11:22 pm
What I did was cut the smog tube off, pulled it threw the fittings so I could still use them. Then I took and tapped the holes to fit I think 1/4 npt plugs
PostPosted: Sat Aug 28, 2010 7:25 am
I will get a NPT tap and try that guys.Thanks
PostPosted: Sat Aug 28, 2010 9:01 am
I picked up two bags of these off of eBay. They should thread right in and not have any clearance issues. Labman is right - they have the same pitch (1.25) as spark plugs.
They can be found here: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180484683636&viewitem=&sspagename=STRK%3AMEWNX%3AIT
PostPosted: Sat Aug 28, 2010 9:07 am
what happens if you don't plug them?
luv less for the time being
PostPosted: Sat Aug 28, 2010 9:34 am
I don't think the oil plugs will clear my valve covers!
If you don't plug them you lose compression and you vehicle won't run right!
PostPosted: Sat Aug 28, 2010 9:46 am
ok i have a solution for you.
remove the factory fittings
remove the tubing from the factory fittings.
cut yourself a slug of metal(sheet, metal,tin, coke can might even work) that is the same diameter as the end of the factory fitting
drop the slug of metal in the whole and reinstall factory fitting to seal it
PostPosted: Sat Aug 28, 2010 10:12 am
Exhaust gases are corrosive.It will eat lead and tin! But thanks.
PostPosted: Sat Aug 28, 2010 10:25 am
ok how about having some one weld the fittings shut and then just stick them back in. tada :D
PostPosted: Sun Aug 29, 2010 4:06 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _822wt_940
M14-1.25 drain plugs, 5 of them for $7 shipped. Just bought some to plug the ports in my turbo block. Used similar ones on my G180.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Tue Aug 31, 2010 3:12 am
The outer circumference of these made contact with the head, so they had to be ground down to a smaller size. The threads were correct though.
Not sure it was worth it... :econfused
At least it's done.
PostPosted: Tue Aug 31, 2010 6:22 am
I guess that didn't work. In the past I found farm machinery the last hold out for American made and customary fasteners. The implement dealers are good places to find stuff not otherwise available. And it is good stuff.
Just for fun, I poked arounjd http://www.fastenal.com/ They have M14 x 1.5 and 2.0 plugs.
PostPosted: Tue Aug 31, 2010 4:27 pm
At least it's done.
I just ground down the outer lip to the hex. My time is free so it's a good price and you don't have to tap new threads into the block or ghetto weld the rail fasteners.
