It is currently Thu Jun 25, 2026 2:21 am
PostPosted: Thu Dec 09, 2010 10:56 am
i thought my motor was complete junk so i didnt set any timing marks anywhere, and i didnt look at where the timing marks where when i removed the head. turns out i have a huge chunk missing from the head gasket, and a small "fixable" dimple on the head. can someone send me a link that has pictures of where the timing marks are supposed to be . spending too much money to mess this up! i have the stock g180 and it's a 79.
PostPosted: Thu Dec 09, 2010 12:22 pm
From my 77 shop manual:
4 Check that the mark on the #1 rocker arm shaft is in alignment with the mark on the camshaft and that the crankshaft is pulley groove is aligned with the TDC mark.
5 Assemble the timing sprocket to camshaft by aligning it with the pin on the camshaft; use care not to remove the chain from the sprocket.
6 install the sprocket retaining bolt and washer....
It also suggests marking the position of the distributor housing before removing the camshaft.
PostPosted: Thu Dec 09, 2010 7:48 pm
timing marks 1.8L stock
Hope this helps if not try the search button
viewtopic.php?f=5&t=12104
