It is currently Thu Jun 25, 2026 1:45 pm
PostPosted: Sat Jun 26, 2010 1:05 pm
Having no luck locating small replacement freeze plugs for the intake manifold.
I have tried several auto parts stores and they can't even order any. Same thing with intake manifold gaskets... I don't need a whole rebuild kit or a head kit.
Any suggestions?
PostPosted: Sat Jun 26, 2010 9:03 pm
Any suggestions?
I heard doorman has them, I need one but have not found it due to time. I got my gasket kit for timing chain and oil pan from Autozone. Had to prepay and order them and got them in 2 days. Everywhere else I had shipping tag on.
Last edited by ethelkilledfred on Sun Jun 27, 2010 12:45 am, edited 1 time in total.
PostPosted: Sat Jun 26, 2010 11:05 pm
i can check with o'reillys tomorrow. i'll let you know what part number they are or if i have some at the store, i can send you some. if nothing else, neoprene plugs might work if you can find a small enough one.
PostPosted: Sat Jun 26, 2010 11:48 pm
Thanks!
They appear to be approximately 18mm OD. I don't have a gauge... just used a wrench. :lol:
PostPosted: Sun Jun 27, 2010 11:33 pm
didnt get a chance to find the right size, but i will check tomorrow morning and let you know in the afternoon. (i get out at 6 pm)
PostPosted: Wed Jun 30, 2010 9:20 pm
ok....sorry for being late, i found a size i THINK is close to what it should be.
the Dorman P/N is a 565-012.1
It's a brass/copper freeze plug that is close to what i measured for the manifold. ( at least the outmost ones on the passenger side)
hope this helps!
PostPosted: Thu Jul 01, 2010 3:45 am
hope this helps!
I know they are normally steel - not sure if it matters.
A man at an old auto parts store in Tomball measured the OD and found some in a catalog. We're pretty sure they are the right size, so I ordered three.
He spent probably 20 minutes trying to locate some, and they were .69 cents each. They will probably come in tomorrow. They still may not be right since they were based on size rather than vehicle application, but for the price it is worth a try...
Thanks for your help! I will post if they work or not and if they do, I will provide the PN and source (apparently they are difficult to find).
PostPosted: Sun Jul 11, 2010 6:29 pm
Well, they came in and actually work well.
They are Federal Mogul Sealed Power and are labeled on the bag as Steel Shallow Cup freeze plugs.
Part number: 381-2180. They came in a bag of 12 at .69c each. I bought them all in case anyone needs one.
Thanks Figuaras for looking!
PostPosted: Mon Jul 12, 2010 11:18 pm
:lol: no problem whatsoever my friend!
