It is currently Mon Jun 08, 2026 5:12 am
 Post subject: Carb problem
PostPosted: Tue Apr 13, 2010 10:21 pm
I have a 79 Luv. It would run fine until I let it sit for a week or so. Then the carb would not get fuel. If I used a compressor to force air into the carb where the fuel line connects, then connected the line back up it would run. I bought a new rebuilt carp thinking something was sticking in the orginal one but it does the exact same thing. Now I can not start it if I leave it for a day. Help???
 Post subject: Re: Carb problem
PostPosted: Wed Apr 14, 2010 1:47 am
I'm guessing fuel pump. Check the fuel preasure with a guage.
PostPosted: Mon Apr 19, 2010 6:57 pm
Mine did the same thing until I changed the fuel filter.
PostPosted: Mon Apr 19, 2010 9:06 pm
Check the filter, don't forget the one actually in the pump itself. If it still does it disconnect the line at the carb and spin it over to see if you're getting fuel there. If so...maybe a stuck/sticking float.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
Users browsing this forum: Google [Bot] and 52 guests
