It is currently Fri Jun 26, 2026 6:34 am
 Post subject: Steering!!
PostPosted: Sat Feb 13, 2010 12:02 pm
I z'ed my frame to bag my luv and I need to find a way to change the steering rod going into the steering box. I dont want to cut the firewall to move it up any suggestions?
"You know you gotta LUV me"
 Post subject: Re: Steering!!
PostPosted: Sat Feb 13, 2010 12:13 pm
Have you ever seen one of these? It relocates the steering.
link>
http://www.speedwaymotors.com/Steer-Clear-Box,6254.html
Info
2006 Best Engineered New Product at SEMA
Finally, a solution to the age old steering column/pedals problem.
This nifty box provides unlimited options for steering shaft clearance so a high performance engine and headers will fit. Allows you to safely reposition the steering column higher, giving you more room for your feet and pedals. Chain drive.
Available in 8", 10", 12", 14" or 16" offsets. Available in brushed or polished finish.
PostPosted: Sat Feb 13, 2010 12:20 pm
They truck cost less than that when I bought it!!!
PostPosted: Sat Feb 13, 2010 3:26 pm
8O :?: huh
PostPosted: Sat Feb 13, 2010 7:50 pm
tj white wrote:
8O :?: huh
It's really expensive.
Price: $599.99 - $699.99
PostPosted: Sat Feb 13, 2010 7:52 pm
If you look at the discription, it's chain driven. You may be able to copy it using motorcycle chain and front motorcycle sprockets going one to one and building a cover for it.
PostPosted: Sun Feb 28, 2010 6:25 pm
Does anyone know the size of the steering column rod so I can get a u joint for it?
PostPosted: Fri Mar 05, 2010 1:05 am
do you mean diameter of the actual steering rod?
if im not mistaken, its just under 1 inch
PostPosted: Fri Mar 05, 2010 1:11 am
oh yeah,
i dont mean to hijack this thread, but i do have a question as to why the steering wheel would be difficult to turn?
i took a look at the gearbox fluid, and it's still full
it feels something like trying to turn when you have a flat tire.
any ideas?
PostPosted: Fri Mar 05, 2010 10:22 pm
Make 100% sure you have good tire pressure. I run 35 psi in mine and it turns pretty smoothly for not being power steering.
Figuarus wrote:
oh yeah,
any ideas?
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sat Mar 06, 2010 11:56 pm
i made sure that both tires were at the right pressure. they are both brand new and have less than 3 tanks of gas on them.
i took a look at the gearbox, and noticed that the pitman arm has some gearbox oil on it. its not dripping, but the truck does leave a small small spot on the ground if i leave it parked for more than a day.
i will need to rebuild the box for sure to make sure that there are no badly worn problems.
BUT,
i need to find a nut for the arm. we had a temporary fix performed when i was in california. so i need to find the nut and get it fixed right.
anyone have a spare? i tried to find one locally, but i'm having no luck so far
PostPosted: Sun Mar 07, 2010 7:48 am
I believe the steer shaft is 3/4" but measure to be sure cause it has been along time since i changed mine.
PostPosted: Mon Mar 08, 2010 8:40 pm
so uh. went scrapping today. and now the steering is stiffer than ever.
hard to turn the wheels in either direction. i'm going to grease the linkage and see if that helps, but i did find that the lower seal is still leaking.
any other ideas?
