It is currently Mon Jun 29, 2026 5:11 am
PostPosted: Sat Feb 20, 2010 9:32 pm
So here's the scoop...
1. Had some noise when make a left turn, like a cyclical rubbing noise.
2. Had to replace the driver's side caliper so I went ahead and replaced pads on both sides and put in new rubber brake lines for each.
3. Greased every fitting I could find while I had the front wheels on.
4. Rubbing is now worse and will now occur sporadically while driving straight.
5. Will rub while rolling backwards slowly (idling backwards)
Things that make it stop:
1. Turning the wheel to the right.
2. Applying the brakes
I'm thinking about putting the old pads back on it (they weren't very worn) and seeing if it makes it stop but honestly I'm not sure what's up. Anyone else had this issue?
Oh, and I could choke Isuzu for not using sealed joints in the suspension. Greasing is a nasty, nasty hobby.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sat Feb 20, 2010 9:43 pm
2 wheel drive? 4x4?
if its 2 wheel i would say wheel bearings are starting to go out
4x4 check the cv boots and wheel bearings
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Feb 20, 2010 9:51 pm
do a component check
lift up the wheel and put your hands at nine and three o clock and move the wheel in and out. if it has much play, could be a steering problem
do the same at 12 and 6 and if it has any play, it will be a wheel bearing problem.
also, find yourself an empty parking lot or something similar, and turn or do whatever it is that causes the noise to occur. stop immediately and look underneath to see if anything is rubbing or out of place.
tire tread faces are great clues as to what is happening with your suspension.
and just a simple thing to do would be to make sure the mud flap protectors are not rubbing or out of place.
PostPosted: Sat Feb 20, 2010 10:00 pm
zyanug wrote:
2 wheel drive? 4x4?
I would concur...
PostPosted: Sat Feb 20, 2010 10:09 pm
Oops, 2x4.
I would've thought if it was a wheel bearing it would be a more constant high squeal instead an on-off low rubbing noise. I'll try to get it jacked up and fudged around with tomorrow. I would like to go through and replace all of the front suspension bushings, joints and bearings but I just don't have the funds for a total overhaul.
Users browsing this forum: Bing [Bot] and 107 guests
