It is currently Sun Jun 07, 2026 11:26 pm
 Post subject: my luv wont run
PostPosted: Mon Feb 08, 2010 2:29 pm
i just bought a 78 chevy luv with the 1.8l isuzu engine, when i bought it the guy said it lost spark so after dinking around with it i got it to have spark but the coil heats up really hot, idk whats up with that any ideas?.......and the bigger prob. is it wont run.. after i got spark i tried starting it and it fired up once and ran for a couple seconds but i had to pump the gas pedal to keep it going and after that i havent got it to start up or do that again any ideas on whats up
 Post subject: Re: my luv wont run
PostPosted: Mon Feb 08, 2010 10:04 pm
I believe you have a short somewhere in your ignition wiring if your coil is getting that hot. It means it's sucking juice from your battery and grounding it out somewhere.
As far as it starting and running for just a second could be a could of things. I would ensure you're getting good fuel to the carb and if you are then I would look at the carb. If it's stock it could need cleaning/rebuilding/replacing. If all of them check out them look at you timing/plugs/wires/etc.
They're pretty simple engines from what I've learned so far from owning mine, just takes a little time.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Mon Feb 08, 2010 10:43 pm
welcome, nice lil rat rod look. as far as your problems goes it does sound like wiring, check and clean the grounds and your battery terminals. corrosion can build up in the clamps of the terminals and cause a poor circuit
If you ain't livin on the edge, your takin up to much space.
PostPosted: Tue Feb 09, 2010 6:54 am
The carb should have a little window on the front of the float bowl. The gas level should be near the mark in the middle. I have had a lot of problems with the float sticking. I finally put plastic spacers to center the float on the pin it pivots on. Once you fix the float sticking problem, you may need to adjust the tab that controls its height. Don't mess with it until you are sure the problem isn't the float sticking. It is a real PITA to set.
I agree, check your wiring. The coil could be going bad too. With the points open, the coil primary shouldn't be grounded. The fuel pump is electric and controlled by a relay under the panel behind the coil. It won't work with the key in run unless the alternator is producing power.
PostPosted: Tue Feb 09, 2010 10:46 am
If the coil is getting to hot make sure that it is wired to the resister.
PostPosted: Tue Feb 09, 2010 11:45 am
ill have to check the coil to see why its getting hot, but as far as plugs go i just changed the plugs, wires, cap, and points, so i think they all should be good, i heard these sometimes jump time on the timing chain, is there any way to check that out??
and it is getting fuel to the carb, and i just replaced the fuel pump also.
PostPosted: Tue Feb 09, 2010 7:34 pm
i spotted your truck on the boise craigslist? you gettin rid of it or did you just buy it?
PostPosted: Tue Feb 09, 2010 8:10 pm
thats weird i dont even live there i live in michigan, i would get rid of it but i dont even know what they go for so....
PostPosted: Tue Feb 09, 2010 9:00 pm
X2, I'm betting the coil is wired wrong, bypassing the resistor.
PostPosted: Tue Feb 09, 2010 10:52 pm
http://boise.craigslist.org/cto/1584738249.html
sorry its 2 years newer but the paint threw me off
PostPosted: Wed Feb 10, 2010 9:59 am
l;ol thats crazy i never would have thought that someone would paint theres the same as i did............i seen it was for sale for 350, is that all one of these trucks is worth not running??
PostPosted: Wed Feb 10, 2010 2:30 pm
Thats what most of these trucks are worth running! :evil:
PostPosted: Wed Feb 10, 2010 2:36 pm
:lol: :lol: it all depends on the condition. if you beat on it and it has some cancer than your lookin at 500 maybe. if you clean it up and drop a fire breathing v8 in it than the skys the limit.
PostPosted: Wed Feb 10, 2010 11:35 pm
I bought my first luv for 100 sold it for 200 then he sold it for 60 then my second luv i bought for 450
2006 GMC Sierra 2500 HD
PostPosted: Thu Feb 11, 2010 12:17 am
bought mine for 200 and may have it sold for 600. i know where a couple more are so im gonna try the case of beer for a car trick :ebiggrin back to the subject did you have any luck so far?
PostPosted: Thu Feb 11, 2010 6:59 am
nope no progress yet, but today im going to take it to a mechanic my dad knows see if he can figure it out, if he cant im prolly going to sell it i just cant put anymore money in to it if there not worth it.....so anyone one looking for a luv?? lol
PostPosted: Sat Feb 13, 2010 12:49 am
If your resistor is bypassed your points will burn surprisingly fast and throw your timing out of whack. I had an ignition switch problem and ran my truck off of a battery to coil jumper wire for a bit. If you dont have a multi-meter buy one. I paid ten bucks for one at pamida inthe bargain bin and ruined it not knowing what I was doing then bought another one the same way. Had it a few years. The wire going to your dist should have less than 12 volts for sure.
1980 4x4
PostPosted: Thu Feb 18, 2010 3:13 pm
okay ive had no luck with the isuzu engine in my luv, i would like to swap it out the easiest way possible, so is there any engines that will bolt to the stock luv trans.
or what engine/ trans would go in easy
im not looking to put a v8 in in, just like a 4 cylinder, or maybe a small v6, or like a dohc engine would be sweet
thanks
