It is currently Tue May 26, 2026 8:39 pm
 Post subject: Cooling system (79 luv)
PostPosted: Sat Jan 09, 2010 11:05 am
Ive been driving my truck around with no heat. It rarely gets hot enough to even defrost the windows. I've made certain that the radiator is clean and the heater core has been cleaned as well. I can feel the hoses being warm. I Bought a tempeture gauge and it doesn't even show a temp (min. 170f gauge) Any ideas guys?
PostPosted: Sat Jan 09, 2010 12:21 pm
I am having the same problem right now. Here is what my plans are: Check to make sure the levers are still attached to their respective valves and doors, ie changing vent to defrost. Then check the heater valve itself as it may be disconnected and/or blocked. I believe my problem might be both, as my heater (hot to cold) lever seems to be really easy to move and I can't get the vent to close. So as soon as I can, I will pull the heater valve off, clean it out and go through the interior unit for anything disconnected or stuck.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Jan 09, 2010 1:35 pm
I removed the valve completely and it didn't change. I'm going to pull the entire heater box and see if there is a crack or something on the box allowing cold air
PostPosted: Sat Jan 09, 2010 3:08 pm
did you also check the coolant to water ratio? running a cooling system with too much antifreeze and not enough water will not allow enough heat to be transferred.
when it was last serviced, did you use the straight gallon, or did you use the 50/50 mixed stuff?
PostPosted: Sat Jan 09, 2010 3:42 pm
Used 50/50 mix good upto -30f
PostPosted: Sat Jan 09, 2010 5:37 pm
Do you have a thermostat in it? Is the eng. warming up enough? Mine (78) will blow hot air on defrost or heat. But not when on vent. So yea, make sure you cables are moving the proper doors under the dash, and make sure the water valve is opening.
PostPosted: Sat Jan 09, 2010 9:11 pm
I was thinking thermostat not in or stuck open.
PostPosted: Sat Jan 09, 2010 9:17 pm
Make sure your water temperature is normal (180*), then with the engine running and heater control on high, feel both heater hoses where they enter and leave the firewall. They both should be hot and at the same temperature. If one is cooler then the other you have restricted flow somewhere, usually inside the heater core itself.
PostPosted: Sat Jan 09, 2010 9:41 pm
Ill give all this a go tomarrow, Ill be working on my toyota and chevy luv at the same time, to keep me from going crazy with the yota lol.
Users browsing this forum: Baidu [Spider], Google [Bot] and 63 guests
