It is currently Mon Jun 08, 2026 11:38 am
 Post subject: Clutch replacement
PostPosted: Wed Jan 06, 2010 12:32 pm
had a lot of different answers from different mechanics, what all do i need to replace the clutch? its a 74 LUV Mikado 1.8L, 4 speed
Perception is 9/10 of the flaw
 Post subject: Re: Clutch replacement
PostPosted: Wed Jan 06, 2010 12:58 pm
i think this should be moved to the stock trucks board...
its just like any other vehicle. you will need to separate the engine from transmission (probably drop the trans will make it easier)
buy a clutch KIT ( Clutch plate, Pressure plate, Bearing ETC)
install according to instructions
make and model of the truck isn't really going to matter.
PostPosted: Wed Jan 06, 2010 2:28 pm
you can get the kit from auto zone or any of those places it is about 120.00 for the kit i got one about 2 years ago and you can do it with in a day or so but make sure you get the kit for your year truck just to be safe :ewink
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Jan 06, 2010 2:35 pm
Most of the threads on here state pulling the engine is the best way for the 4x4's...
PostPosted: Wed Jan 06, 2010 10:41 pm
I'm with mytmouz, just yank the motor and trans. lot easier you will have to get some one pres on/off the throwout bearing, unless you have an arbor press. Take the whole thing to the car wash clean it up put it back in looks nice.
PostPosted: Thu Jan 07, 2010 2:24 pm
and with the 2 wheel drive you can do it with out puling the motor i did and i used a puller to get the throw out and i put the new one in my self i did all the work my self but make sure you clean the fly wheel real good
dangerous-toys4life
75 k-5 2x
94 king cab
Users browsing this forum: Google [Bot] and 57 guests
