It is currently Mon Jun 08, 2026 1:37 am
PostPosted: Sat Nov 14, 2009 2:19 pm
Ok so my first problem. My wipers don't work. Well they go up but not down so I pulled the motor out and took it apart and the plastic gear on the inside is stripped in one area. Now I have been to all 5 parts stores in town and no one can even ORDER me the motor and all I find online are for 81~not helpful so I need to know where I can get one of if I could somehow reapir the one I have. I would like to just find a gear if anyone knows of any that will interchange but if I have to buy the entire motor so be it. HELP! Thanks.
PostPosted: Sat Nov 14, 2009 2:57 pm
Junkyard maybe. Maybe you can look into the older isuzu pickup trucks and get lucky. I have done that a time or two.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Nov 14, 2009 3:14 pm
how bout this one
http://www.autozone.com/autozone/catalo ... entId=57-0
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Nov 14, 2009 3:29 pm
Yes I went to autozone and when you try and order it the computer says no way, I can't order it from anywhere. No way I'm the only one to have a wiper motor go out! I have been told at the KC pick n pull they have one luv, guess I'll have to check that out.
PostPosted: Sat Nov 14, 2009 4:18 pm
Ok think I found it. Doesn't say for an 80 luv but looks 100% like the one I pulled out. What do you all think? http://cgi.ebay.com/ebaymotors/Windshie ... ccessories Wish me luck.
PostPosted: Sat Nov 14, 2009 4:34 pm
says 81-82 luv on it and a different part # than the 1 at autozone so i wouldnt think so
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Nov 14, 2009 9:06 pm
True but it's a reman, so I hope thats why and autozone no longer even carries the other one so that part number is no good anyway. It looks like a mirror image of the one that came out so that gives me hope. Even the connector is the same. At the leaset I should be able to pull the gear out of it.
PostPosted: Sat Nov 14, 2009 10:13 pm
i have good used motors if all else fails...
PostPosted: Mon Nov 23, 2009 2:44 am
Just so you all know that motor will work. It plugs right up but does fit kind of funny but with some longer bolts works just fine.
