It is currently Mon Jun 08, 2026 3:04 am
 Post subject: headlight issues
PostPosted: Sat Nov 07, 2009 10:26 am
so my pass. side headlights are really dim,also the high beams look like they are trying too come on when they shouldnt? I will be troubleshooting this weekend but thought id check with you guys first,thanks
76 mikado project,mean green
 Post subject: Re: headlight issues
PostPosted: Sat Nov 07, 2009 10:51 am
Check your grounds...
PostPosted: Mon Nov 09, 2009 3:02 am
I am also having head light issues. Mine won't come on at all and the guage cluster won't light either. Could this also be grounds or the dimmer/turn signal switch? If it is a ground where would the one I need to check be located? The fuses look ok and I already put in another headlight switch and still the same problem. I also looked at the wiring diagram in my shop manual, but I really can't figure it out much from that.
http://www.purerockradio.net/
PostPosted: Mon Nov 09, 2009 11:50 am
if you have the fuse block under the hood. the last fuse is the lights. if you pull it out does it look melted? i was having trouble with mine and that was the cause. i had to jimmy it and clamp it to make it work
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Wed Nov 11, 2009 5:40 am
I looked at the fuses again and they all look good and are in nice and tight. Is there a ground for the headlights under the dash somewhere? The gauge cluster won't light either, but all the other lights work. Could the dimmer/turn signal switch cause any problems with this?
PostPosted: Wed Nov 11, 2009 9:00 am
I think there is an inline fuse coming off the switch. It might be the red wire. Also you might try getting a piece of wire with alligator clips on each side and try grounding your switch to a bolt or something metal to see if it is a ground. check your connections at the switch also. You may not be getting goo contact with one of your wires. It sounds like a ground problem. You might put a new fuse in also because I have had fuses that look good but are bad.
PostPosted: Wed Nov 11, 2009 12:35 pm
As was said above it nearly always is a grounding problem. Headlight ground connection should be at the coil mounting on the right side inner fender and at the regulator mounting on the left side. Check also that the negative battery cable is grounded to the engine as well as to the body near the battery. That is where I would start.
PostPosted: Wed Nov 11, 2009 1:15 pm
I played with the wires under the fuse box and it helped so I'm gonna recondition my fuse box,STILL NEED A COVER!!!
PostPosted: Thu Nov 26, 2009 6:02 pm
why your at it go to ebay and get some 7" headlight conversions. I installed them last night and they are great. 18 bux and 10 min to install.
PostPosted: Sat Nov 28, 2009 10:40 pm
i also am having some trouble with my low beems on the dr side is on then with the high beems on both ps go on i am lost
dangerous-toys4life
75 k-5 2x
94 king cab
