It is currently Sun Jun 07, 2026 10:28 pm
 Post subject: Floor pans
PostPosted: Fri Nov 06, 2009 9:44 am
Any of you guys know a company that has floor pan replacements for my 80 4X4 that I bought new. Had a leak on the right side of the cowl section & put off repairing it to long. Had to remove fenders, windshield & top portion of cowl to get to it. I couldn't see this until we got the fenders off but no drain holes were made so water could get out. We can fabricate one if necessary. Any help appreciated. This little truck is family, we've been places together.
 Post subject: Re: Floor pans
PostPosted: Fri Nov 06, 2009 3:45 pm
Good luck finding them...I made mine. Welcome to the site.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Nov 07, 2009 10:34 am
I know this is a little late but apparently a lot of leaks come from the w.wiper posts.was told from this site to use old spark plug boots !!!
76 mikado project,mean green
PostPosted: Sat Nov 07, 2009 12:28 pm
Thanks, I already made that application a few years back & it looks & works good. This leak is around the air duct on right side. We're either going to cut out the rust & apply new metal or grind it down & lead it. The important thing is kill or remove the rust or it will be back.
PostPosted: Sun Nov 08, 2009 4:32 am
This is pretty much one of my favourite threads on this site:
viewtopic.php?f=7&t=7163
It's all about rust.
PostPosted: Sat Nov 21, 2009 6:38 pm
It be nice if they had a company that made them. You can get a lot of floor pans for 70's VW in JC Whitney, but not a Luv. Go figure. :roll:
I've gotn to a sheet metal fabrication shope before for thigns like my window rails. I would think they coudl come up with some floor pans and weld them in for you.
PostPosted: Sun Nov 22, 2009 4:27 am
There are millions of VWs... but only thousands of LUVs... Bummer, but that's the way these little trucks are going.
Everything eventually comes to an end, but commonality definitely pushes out the final days.
PostPosted: Sun Nov 22, 2009 1:24 pm
Got a leak somewhere, maybe I will check that.
PostPosted: Tue Dec 15, 2009 2:04 pm
hey, hope this isnt considered an ad, but if you need, i will have a complete cab available soon.
where are you located? i might be able to have it shipped to you for relatively cheap...
PostPosted: Fri Dec 18, 2009 11:40 am
This problem has been solved. Thanks.
