It is currently Mon Jun 08, 2026 5:30 am
PostPosted: Fri Oct 23, 2009 9:54 pm
My starter finally bit the dust, any advice on R&R, the top bolt looks tought to get at.
this is on my 80.
PostPosted: Fri Oct 23, 2009 11:50 pm
the best way is a u-joint socket and an extension with a stubby ratchet. thats what i did.
PostPosted: Sat Oct 24, 2009 4:16 pm
i believe its a 12 or 14mm socket you will need
PostPosted: Sun Oct 25, 2009 3:26 pm
This may sound real stupid but: make sure you disconnect the battery cable before you start. BIL did a studid--- With the car up on blocks and while wrenching on the starter, the wrench shorted a wire connection against the engine block. Sparks flew, the engine started cranking over, and because he left it in gear it lurched ahead off of the blocks, dropping the car and pinning his head between the frame and the ground. His friend got the car off of him and only minor injuries resulted.
One lucky dude!
PostPosted: Sun Oct 25, 2009 5:32 pm
It is no fun. I have a very long extension I work in from the front of the engine. It is actually a stud that screws into the transmission. Yes, it is a 14 mm nut on it.
I don't think I have had to replace my starter since I switched to 5W-30 oil 15+ years ago.
I did have to replace the clutch about a year ago, and then a few months later the throw out bearing again I had bought at Oreily's along with the clutch. I have had some bad luck with some of their other stuff too. I think NAPA will be seeing more of me.
PostPosted: Sun Oct 25, 2009 8:06 pm
I got it out, it looks like the original starter, it was a pain to get out but it should go back in easy, I hope. I had to use a long extension and go under the intake to get the top nut off.
PostPosted: Sun Oct 25, 2009 9:09 pm
glad it worked out!
PostPosted: Mon Oct 26, 2009 4:45 pm
It went back together nice and smooth, I replaced all the battery cables also. It fires up like a new one.
PostPosted: Mon Oct 26, 2009 6:12 pm
I could only find refurbished starters through kragen and i literally went through 13 of them before i got one that lasted more than a couple months.
PostPosted: Tue Oct 27, 2009 1:40 am
Don't they offer that limited lifetime warranty?
PostPosted: Tue Oct 27, 2009 4:52 am
What a pain.
PostPosted: Tue Oct 27, 2009 1:25 pm
yeah, i think there is a reason for that..... they must know that they are selling some crappy stuff. luckily, i haven't had to use warranty for the parts i've purchased there
PostPosted: Wed Oct 28, 2009 10:34 am
Ya they were all free after the first but it was still a pain in the A$$
Users browsing this forum: Google [Bot] and 40 guests
