It is currently Sat Jun 27, 2026 4:03 pm
 Post subject: Electronic ignition
PostPosted: Tue Feb 10, 2009 1:41 pm
Anyone can help with the upgrade of my 80 Chevy luv? What engine type or distributor is need?
 Post subject: Re: Electronic ignition
PostPosted: Tue Feb 10, 2009 5:18 pm
sleeps at LUVTruck.com
I have a 79' 4x4 and i used pertronix to upgrade to electronic ignition. You can also use a 81-82 luv distributor but make sure to also get the ignition module when getting one. (located on the ignition coil i believe). Ctmandu said that late eighties (idk the exact years) models isuzu pickups have internal ignition modules so it makes the install a little bit easier. Ctmandu may chime in later. But search and youll find plenty of info.
PostPosted: Tue Feb 10, 2009 5:20 pm
Try this.
viewtopic.php?f=7&t=18548&p=136094&hilit=electronic+ignition#p136094
