It is currently Sun Jun 28, 2026 6:04 am
PostPosted: Tue Jan 27, 2009 6:28 pm
the diesel luv i was suppose to try to get to run today doesnt have a key. i either have to fork out money to have a guy come make me one that i wont ever use after i make sure the engine runs or i can hotwire it... anyone have any ideas?
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Tue Jan 27, 2009 7:09 pm
I would ask in the diesel forum here. I am sure it should be easy.
PostPosted: Tue Jan 27, 2009 10:24 pm
It's easy. I hot wired mine. Look at the wiring diagram on this site for the series truck you're checking out. acc, hot, and a couple others need to touch all at once. don't forget to push in the clutch when you try it. the diagram pretty much is self explanatory
PostPosted: Wed Jan 28, 2009 4:32 am
Australian LUV Guru
Jam a big flat blade screwdriver in the keyhole and twist :twisted:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Jan 28, 2009 10:09 am
i guess i forgot to mention that it is a 72 chevy luv with a diesel in it and some type of isuzu steering wheel with the key on the side of the column... so some more info i guess to think over.
PostPosted: Thu Jan 29, 2009 12:36 am
I agree with the screwdriver idea.
Hotwiring a luv with the key in the regular place is not hard. That, on the other hand, might be tricky.
PostPosted: Thu Jan 29, 2009 9:19 pm
well i did the screw driver thing and for some reason it only let it turn over once... after that it wouldnt even clik any ideas?
PostPosted: Fri Jan 30, 2009 7:17 pm
Is the battry dead ?
currently working on my 1977 luv truk
PostPosted: Fri Jan 30, 2009 8:57 pm
the battery is currently in my 76 luv and it runs and is fine so its not the battery. and an update for all the people who might need to hotwire in the future... after destroying the switch with the screw driver and it not working real great and breaking my screwdriver in the process i took the shroud off and started looking at everything... there are two little screws that hold the tumbler on... i didnt know this on the opposite side and if you unscrew them as i found out the whole tumbler comes off and you can do what every you want with no breaking things! the things you learn when you pay attention... well off to the diesel forum to trouble shoot this problem
Users browsing this forum: Bing [Bot] and 71 guests
