It is currently Mon Jun 08, 2026 5:29 am
 Post subject: headlight switch?
PostPosted: Mon Dec 01, 2008 3:41 am
driven down the road tonight and both my headlights went out , but the dashlights stayed on??? the headlights came back on in a few sec. so i didnt think much about it but then it happened agean and i bout ran into a ditch . the trucks ok but it scared the shit out of me. ive got two foglights hard wired with a relay to the highbeams and it happened when i had the highbeams on.. so would it be the switch or is the a headlight relay ??
DITCH DIGGER 16550
 Post subject: Re: headlight switch?
PostPosted: Mon Dec 01, 2008 11:34 am
Sounds like it might be a loose plug or wire connection. Start there 1st.
PostPosted: Mon Dec 01, 2008 11:50 am
correct me if im wrong but the high beam switch is on the floor{dont use highbeams alot} and i have changed out many many of those because water runs right down on them if you have any kind of leak, they are usually just a couple dollars but that has been the cause of loosing headlights for me in the past
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Mon Dec 01, 2008 12:26 pm
There is a thermal circuit breaker for the headlights under the dash on 78-80 trucks that can trip and reset itself. Sounds like that is a likely suspect since you've got something else wired in with the headlamps. If you have the fog lamps on a relay, you might go ahead and covert the headlights to run off a relay directly to the battery too. Eliminating the switch and all that extra wiring before the lamps would take load off the circuit breaker and the headlights will shine brighter anyway.
On 77 and older there is a single fuse, headlight switch, that can blow or get flakey and take out all the lights at once.
PostPosted: Mon Dec 01, 2008 8:51 pm
ok it was the circuit breaker so i rewied the foglights on their own switch. thanks for the help
DITCH DIGGER 16550
PostPosted: Mon Dec 08, 2008 10:36 pm
"On 77 and older there is a single fuse, headlight switch, that can blow or get flakey and take out all the lights at once."
Thanks, 800XL! Some wild roads here and REALLY don't need to do the shot in the dark thing, really...
Hey, on those driving lights: almost sounds like they're wired wrong? Should have direct 12V battery voltage to one side of relay and to lights, and the other side is the control circuit, which would be wired to switch of choice. If you're tapping headlight wires for power to the driving lights that ain't gonna get it! Same goes for using relays on the headlights, direct battery voltage to one 'side' of relay, other side is control circuit.
PostPosted: Tue Dec 09, 2008 9:08 am
That fuse almost killed me once when I was on a logging road doing about 50ish sideways around a corner spitting gravel and hit a bit of a pot hole. Every light went out and I was left getting the truck Whoa'd by feel with a steep drop on one side and a rocky cliff on the other. Once I got stopped I looked at the fuses and found nothing wrong. I popped that fuse out of the panel and the lights flickered, checked the fuse over good and one end fell off in my hand. Hmmm, mystery solved!
