It is currently Mon Jun 08, 2026 12:55 pm
 Post subject: 6-lug to 5-lug wheels?
PostPosted: Mon Oct 13, 2008 2:13 pm
Has anyone done this? Can this be done with Chevy parts from other vehicles? There are SO many more choices in wheels using a 5-lugs.
Thanks
PostPosted: Mon Oct 13, 2008 8:15 pm
yeah their have been threads on here swaping out spindles to a s10, or toyota hub assembly will work with modification and supposively a monza will as well? I am wanting to do this myself also... I have a 5 lug rear.
the last option buying the kit from aerospace company which comes with both the 5 on 4.5 or 5 on 4.75 I had it priced the other day for 710.00 for it through autofab.com (not the dragster setup) kinda pricey but great product so I am considering other ideas for right now.
PostPosted: Wed Oct 15, 2008 2:50 pm
http://forums.luvtruck.com/viewtopic.php?f=5&t=16956&p=125373&hilit=s10+spindles#p125373
Here is a post about swapping front spindles and leaving the stock LUV a arms in place. I think it requires making an adapter for the lower balljoint (so a S10 balljoint can be used) and drilling the top a arm for the upper S10 balljoint.
Then swap in a S10 rearend (it bolts in, I have one in mine.) Not sure if the driveshaft will work but i am getting mine cut down locally for $70.00.
Users browsing this forum: Baidu [Spider] and 28 guests
