It is currently Tue May 26, 2026 1:55 pm
 Post subject: need a Mech GURU
PostPosted: Tue Jul 22, 2008 5:51 pm
o.k., so i'm sooooo annoyed with this! Trying to get the tranny hoses off the radiator. And I know its some little thing i shouldnt bitch about... but anyone got an easy way, this has become a pain in my ass......LOL
whats the trick to getting these off? I'm affraid I'm gonna brake them.
 Post subject: Re: need a Mech GURU
PostPosted: Tue Jul 22, 2008 6:01 pm
typically I can just use two wrenches... putting the wrenches close together so they wont loosen much the first time, and all you have to do is squeeze one hand.
NM... too hard to describe....lol
You can also use line-wrenches. Kinda like the box-end wrench with a slot cut in it.
Soak it in some PB blaster.
Cuss at it, ask it nicely, shake your fist at it... ummmm
Go get dad. On second thought, might not be a good idea. Go get mom.
PostPosted: Tue Jul 22, 2008 6:13 pm
You WILL need a line wrench so you don't round out (anymore) of the hex.
PostPosted: Tue Jul 22, 2008 6:46 pm
o.k., not trying to be an ass...just frustrated.
but i know its 2 wrenches..... I dont live at home....
So, i got the wrenches and i got them to brake loose, but only one turns,the hose end....
when i try to loosen them the hose just twists up in a knot before its all the way off. Irritating.
So mabey i should have worded my question better, but now that i've explained it, anyone have a better suggestion? I'm half tempted to just cut them in half, remove them and go buy another set. But I thought i would ask before i waste money.
Gary
PostPosted: Tue Jul 22, 2008 6:49 pm
The fitting on the hard line side should spin. Spray in something like WD-40 or PB-Blaster and try holding the hardline and get the fitting to break loose and spin.
PostPosted: Tue Jul 22, 2008 6:51 pm
its doing that but it seems to bind up before it comes off, should i just keep letting it bind? is that normal?
PostPosted: Tue Jul 22, 2008 6:52 pm
I hate doing this, but it is so easy, what about a small pair of vice-grips on one end and a wrench on another?
If it is binding up, then try working it loose-tight, loose-tight, the binding should get easier, however this is usually indicative of a stripped thread.
PostPosted: Tue Jul 22, 2008 6:56 pm
If they are a pain in the ass now,they will be just as bad later.
IMHO,unless you are on a limited budget I'd cut em and get new ones.
PostPosted: Tue Jul 22, 2008 7:02 pm
they are not stripped.....
the hose is binding when i turn it to loosen. It binds around its self.
NM, I'll just cut them. Hopefully its not a hard part to find.
PostPosted: Tue Jul 22, 2008 7:04 pm
IC. You can still put the vice-grips on the crimp-seal behind the hex. Be careful not to crush it, though. If your truck is your only mode of transportation, I would not cut them unless Autozone is right down the street.
PostPosted: Tue Jul 22, 2008 8:01 pm
you could also get a piece of sand paper or emery cloth and clen the hard lines they look pretty corroded
PostPosted: Tue Jul 22, 2008 8:39 pm
LOL - i take it you havent seen the pics of my build. This thing is a rust bucket.
