It is currently Tue Jun 30, 2026 5:42 am
 Post subject: fuel tank sender
PostPosted: Wed May 07, 2008 9:22 am
is the stock fuel level sender a regular 90 ohm GM, or is it something else? the reason im asking is because im looking at this fuel gauge for my project luv. thanks!
http://www.iequus.com/product_info.php? ... id=100_105
(PLATINUM STREET RODS)
Deming, NM
 Post subject: Re: fuel tank sender
PostPosted: Thu May 08, 2008 5:17 am
My '79 factory manual gives the following specs for the fuel sending unit
Full position: 14.9 to 19.1 ohms
Half full: 40.5 to 49.5 ohms
Empty position: 113.5 to 126.5 ohms
PostPosted: Thu May 08, 2008 4:15 pm
If you are going to use a after market gm gauge, you can get an after market gm fuel sending unit from JC Whitney Co. You will have to cut the unit to fit the gas tank, and do some minor drilling out of the mounting holes to get it to fit. The instructions will tell you what you have to do.
