It is currently Mon Jun 08, 2026 12:54 pm
 Post subject: Carb
PostPosted: Tue Jan 29, 2008 6:27 pm
ok i know weber is the way to go for carbs but i have to stay leagle did holley make a carb for these trucks?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue Jan 29, 2008 7:50 pm
No. They did do some rebuilding of the stock ones and sold those years ago.
I got a fresh new rebuilt stock carb from a local auto parts store that is working well. It was $400, but it works well.
PostPosted: Wed Jan 30, 2008 2:03 am
There is an Offy manifold for the Holly carb, but I don't know much about that. For probably right around $500 you could get a brand new Weber carb and an Offy intake and probably be way better off than a rebuilt carb on the stock intake.
http://www.purerockradio.net/
PostPosted: Wed Jan 30, 2008 9:59 am
Staying legal would generally mean keeping the stock carb.
Depending on what the rules are you might be able to retro fit up some sort of EFI to the motor. Id still say it would be emissions test dependant the same as a carb swap.
Bob.
