 Post subject: truck wont start
PostPosted: Sun Sep 09, 2007 4:56 pm
when im cranking the starter it will run but when i let off the coil looses its 12 V and dies. Havent had time to tear into it yet, just wondering if anyopne else has had this problem
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Tue Sep 11, 2007 4:39 pm
It is either the ballast resistor or the relay that drives it. Unhook both ends of the resistor and check it for continuity or measure out the ohms on it. (Assuming you have a multimeter at least) I forget what the ohm rating on it is but its in the service manuals, even the haynes.
To test the relay system, hook 12v directly to the coil and see if you get any voltage to the resistor once the truck is running.
PostPosted: Tue Sep 11, 2007 6:28 pm
its the ballast resistor, $17.95. I can afford that. I talked to a guy at work and he told me to check that out too. Thanks for the help
PostPosted: Mon Sep 17, 2007 9:56 am
yeah, been through that before...
