It is currently Mon Jun 08, 2026 9:22 pm
 Post subject: Horn wont work!!
PostPosted: Mon Jun 04, 2007 6:24 pm
So my 79 didn't come with a horn, the guy took it out or something. but I was at a U-pull-it like 2 weeks ago and found a wrecked like.. 76 or 77 im not sure, it was extremely sad, but I took the horn from it :-p, and My wiring for the horn doesn't work, so can someone tell me how to re-wire?
Would the haynes manuals have it in there? I just realized that so im gonna check, but any help is great.
Thanks guys.
PostPosted: Mon Jun 04, 2007 8:35 pm
I had a problem with my horn not working and it ended up that the steering wheel would not ground out to the steering column, but the column was grounding to the frame, so I ended up taking a thin spring from a plate hanger and attached it from the steering wheel to the steering column . Now I have a horn.
The previous owner had taped a horn button on the steering column and hook a wire from a 12 volt source to the button and ran it to the horn.
I didn't like that ugly look and wanted it to work correctly from the factory as much as possible.
PostPosted: Mon Jun 04, 2007 9:46 pm
my horn button is actually on the side of the steering wheel, as part of the dash. and im not sure if the wires got cut along the route somewhere, as its covered with tape.
this is hard for me to try and explain, so bare with me and tell me if this will work.
if i could route a wire from the button, pos. terminal, to the battery pos. then routed another wire from the botton, pos. terminal to one side of the horn itself. then grounded the button, and grounded the horn. when i press the button will it connect the circuit or w/e and blare the horn?
I'm going to try it but I'd like to get some advice first incase i short out something. haha I just need a horn, my cherry bomb popping at people at 3200 rpm's isn't workin out great, it just scares the s@#t out of them. haha
thnx again guys.
PostPosted: Mon Jun 04, 2007 9:55 pm
Usually the horn will work off of a relay. The button will connect the ground to the relay. The relay will then send + down to the horn.
PostPosted: Mon Jun 04, 2007 10:39 pm
oh.
could someone like take a pic of their horn in the luv, the stock one, and then a pic of their relay?
and wiring or w/e. that would be awesome. im not sure if i have a relay or w/e on mine.
thnx
PostPosted: Tue Jun 05, 2007 6:08 am
Mine used to work. Took it off and painted it and Wahlah, now it doesn't
PostPosted: Tue Jun 05, 2007 11:12 am
lol ouch
PostPosted: Wed Jun 06, 2007 3:02 pm
You can use any horn off any vehicle, make sure the horn is good,get some wire and wire the horn and then touch the battery.
http://www.thebugshop.org/images/site/horn4.jpg
PostPosted: Fri Aug 10, 2007 4:16 pm
so i've been trying since the day i got this horn off of another luv in a junk yard (poor luv) and I STILL can't get it to work, I have no idea if I'm wiring it right or anything, I just want to see if the horn works, then I'll worry about wiring it later.
I've put a ground on one tab of the horn, and then touched a side with a wire hooked to the + of the battery.
and nothing.
I've wired the tab to the negative side of the battery, then the other tab to the positive side, and still nothing.
Is the horn bad? or am I just an idiot and hooking it up wrong.
Thanks guys
PostPosted: Fri Aug 10, 2007 4:29 pm
I just use my finger 8)
You can test the horn... put the leads directly on the battery...beep is good, no beep is no good
You can buy a cheap horn at the parts store ya know
PostPosted: Fri Aug 10, 2007 8:40 pm
If it is a stock horn like on my 78, mine quits working every so often (think it corrodes up). There is a screw on the back side of it with a nut on it, I have to loosen the nut and adjust the screw a turn or two (cant remember in or out) and tighten the nut back down and the horm beeps loud and clear again.
PostPosted: Fri Aug 10, 2007 11:31 pm
PITA Old Fart
Every time mine starts acting up I just smack it a few times with a screwdriver handle and squirt a little WD40 in it and it starts working again.
I firmly believe that should be the official GM/Isuzu method of repair for all of their horns...lol
PostPosted: Sat Aug 11, 2007 10:11 am
Ever try fixing a couple of Peterbilt air horns that are all clogged up with years of bugs? :smt104
I hate guys that won't spend $10 on horn covers. :smt011
PostPosted: Sat Aug 11, 2007 4:39 pm
PITA Old Fart
Yep...been there - done that. It's a real messy PITA to get them working again.
