It is currently Mon Jun 08, 2026 2:15 pm
 Post subject: My first pickup
PostPosted: Mon Jun 04, 2007 12:36 pm
I got a 79 chevy luv for my 17th birthday, and it's my first vehicle. It's a very fun ride, and i drive it everywhere. I installed a new Wal Mart stereo the first month i got it. It was a little tricky, due to the fact the kid before had a CB installed. Right now my clutch is going. I was wondering if that is a common problem Luvs, and if anyone had any tips on fixing it, or if i just need to replace it.
PostPosted: Mon Jun 04, 2007 6:36 pm
How many miles on the truck. Is it slipping. I would replace it and the pressure plate that way you know what you have and be good to go for a long time. Of course unless you do the old hold on the hill with the clutch routine all the time. :lol:
PostPosted: Mon Jun 04, 2007 7:09 pm
don't forget to check the clutch fork when you have it out,I had one that cracked at the ball and didn't notice it till the 3rd time i pulled the tranny! :lol:
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Sat Jun 23, 2007 4:11 pm
hrm... ive to0yed with the clutchsince then, and it is doing better. I thinkmymain problem is the clutch cable, which is really stretched out. I adjusted it but it is a very temporary fix. My top speed is now about 50 in 4th : ) .. You guys were talking about the <dutch> what is that and what do i have to do to check it. I am going to teare out the clutch when I replaceit, so i want to know what to do to check that out in the process. Thanks guys foe the help so dar, its been great!
PostPosted: Sat Jun 23, 2007 4:13 pm
Durrr. i meant <clutch fork> ... i need to preview my next comment before i post : P
PostPosted: Sat Jun 23, 2007 5:37 pm
check the pedal barkit and see if its broken that would make it hard to shift if it is have fun fixing it
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sun Jun 24, 2007 8:59 am
Chavy has a good point. Check the bracket under the dash that the clutch pedal hands from. They get bent, loose and crack and brake. If it is bent badly, it could not let you push the pedal to the floor.
PostPosted: Sun Jun 24, 2007 11:09 am
I have now had that problem with 2 LUV's! :evil: It is a pain to pull out that bracket, but once you do you can get a shop to weld it up and it will be as good or even better than new. It is almost worth it to pay to get it welded than to buy another used bracket for fear of the same thing happening!! That's just my 2 cents worth.
