It is currently Tue May 26, 2026 5:02 pm
 Post subject: Carb. Problems
PostPosted: Tue Apr 08, 2003 8:15 pm
I just re-tuned my motor and it runs like a clock but it has a hesitation when I start pressing the pedal to the floor.I havent driven this truck for about three months,Is there gum build up in the carb. :?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Apr 08, 2003 9:34 pm
Check your timing, vacuum advance and make sure that when you work the throttle lever on the carb a little bit of gas squirts into the carb. If you don't get any gas when you press on the pedal, you need to rebuild the accellerator pump.
-DK
PostPosted: Wed Apr 09, 2003 12:52 pm
sounds like an accel pump or timing advance.
PostPosted: Wed Apr 09, 2003 5:28 pm
I already checked the points gap and I redid the timing.I fixed the float assembly and rebuild the carb.Ill take a look at that.Thanks :D
1975 V8 Luv
1980 Bagged Luv
Users browsing this forum: Bing [Bot] and 61 guests
