It is currently Tue Jun 09, 2026 11:14 am
 Post subject: Intake gaskit
PostPosted: Tue May 08, 2007 4:17 pm
If one where bad go that cause a water leak?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Tue May 08, 2007 6:52 pm
are you having an external coolant leak problem?
PostPosted: Tue May 08, 2007 7:38 pm
Swap Specialist Mod
is it leaking by the thermostat housing? or towards the rear of the engine?
theres 2 coolant passages that can go bad on these engines. one is where the coolant flows from the head to the thermostat housing. then theres one thats between the #3 and #4 intake ports.
 Post subject: .
PostPosted: Tue May 08, 2007 8:27 pm
yea its external leak I cant tell where it is tho truck is running great so I dont think its a head gaskit
79 4x4 1.8 liter
PostPosted: Tue May 08, 2007 8:34 pm
you can always use some coolant dye if your unsure or have a hard time finding it.... But Id look at what some of the more experienced 1.8 owners have to say, like Farmer Joe
Coolant dye is about 5-10 bucks and a black light to see the dye is another 5 bucks or so. If you do it in the dark you will see the dye alot more clearly.
Users browsing this forum: Google [Bot] and 43 guests
