It is currently Mon Jun 08, 2026 11:38 am
 Post subject: Double Filament Globes
PostPosted: Fri Apr 20, 2007 1:31 am
Australian LUV Guru
Why are there double filament globes in my parking lights of my 1980 Luv
PostPosted: Fri Apr 20, 2007 3:27 am
I believe they also serve as a turn signal.
PostPosted: Fri Apr 20, 2007 3:38 am
Australian LUV Guru
i have a clear section for parkers and amber for turn there is a double filament in the parker why is this
PostPosted: Fri Apr 20, 2007 3:53 am
Australian LUV Guru
Im talking bout the park/turn lenses in the front of my 1980 bumper
PostPosted: Fri Apr 20, 2007 10:34 am
I don't know about Australia, but here in the states they are a park/turn combo. Turn signals require a much brighter light than the park lights. One filiment is used for park and the other for turn.
PostPosted: Fri Apr 20, 2007 2:14 pm
The side marker and front turn setup is different in the Oz luvs from the US so we are going to be pretty clueless. Over here we just have one bulb in the bumper park/turn combo lights.
Pull the bulb and make sure the socket it is in has two contacts. Could be someone just put in the wrong bulbs.
PostPosted: Fri Apr 20, 2007 2:42 pm
Australian LUV Guru
There is two contacts in the socket and two wires running up in to engine bay only one is connected
PostPosted: Fri Apr 20, 2007 3:51 pm
I bet they just used the same parts for US and Aus markets with different lenses to save money. No sense in designing and making two different parts at the factory when one can be used for both.
PostPosted: Fri Apr 20, 2007 5:07 pm
Australian LUV Guru
Thanks 800xl that would be why :D
PostPosted: Fri Apr 20, 2007 5:10 pm
What the heck, might as well wire them up to do something. 8)
PostPosted: Fri Apr 20, 2007 5:19 pm
Australian LUV Guru
If conect the second wire it lights the second filament in the globe Increases the brightness of the park light, not much point doing that
PostPosted: Sat Apr 21, 2007 2:09 pm
You could wire them to an alternating flasher so they'd blink back and forth. Then go play undercover cop or something. ;) Only other idea I'd have would be to use them as flashers for an alarm system or something, they would be brighter than just the standard parkers.
Users browsing this forum: Google [Bot] and 57 guests
