It is currently Mon Jun 08, 2026 12:54 pm
 Post subject: brake booster removal
PostPosted: Thu Mar 15, 2007 5:43 pm
ok... whats the deal?
the four bolts are out, but it looks like there is a special nut where the shaft goes through the firewall
is there a special tool for it or something?
It looks like a nut with only four tangs sticking out on the sides.
PostPosted: Thu Mar 15, 2007 6:16 pm
PostPosted: Thu Mar 15, 2007 8:46 pm
no one?
humm.. :smt100
PostPosted: Thu Mar 15, 2007 9:17 pm
I removed one a while back.. but I can't remember what I did.
Sorry
PostPosted: Thu Mar 15, 2007 9:42 pm
Once the 4 nuts are off, the only thing holding it is the factory sealant between it and the firewall. The last one I removed I had to pry off...The piece you are thinking is holding it on is part of the booster itself and is not keeping it from coming off. :?
PostPosted: Thu Mar 15, 2007 9:58 pm
Keven is correct.
PostPosted: Fri Mar 16, 2007 9:15 pm
that is what I was thinking... but I just didn't remember and didn't want to steer in the incorrect direction.
PostPosted: Fri Mar 16, 2007 10:42 pm
well I learned that if pulling on it dosent work... get the 3 ft pry bar out
and ta-da!
It was just really stuck in there..
Those tangs were just for the rubber boot
PostPosted: Sat Mar 17, 2007 10:24 pm
Yep. :lol:
