It is currently Wed May 27, 2026 4:11 pm
 Post subject: Worn ignition switch?
PostPosted: Sun Mar 18, 2007 7:19 pm
Is it common for the ignition switch to turn with a friggin common screwdriver or pocket knife?
Mine does,and I just discovered this early this morning when my wife walked out to go to work and found my LUV running with the passenger side door ajar..... 8O
Found the ignition turned on and a small reg. screwdriver on the front seat.
PostPosted: Sun Mar 18, 2007 9:31 pm
Well both of mine did until i got a new ignition switch.
PostPosted: Sun Mar 18, 2007 10:47 pm
the housing wears out before the pins do
 Post subject: bummer...
PostPosted: Sun Mar 18, 2007 10:50 pm
sounds like someone was trying to steal your LUV from ya.... Time for an alarm...
PostPosted: Mon Mar 19, 2007 1:19 am
or a shotgun...
PostPosted: Mon Mar 19, 2007 8:27 am
Or both...
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
