It is currently Sat Jun 13, 2026 5:30 am
 Post subject: Intake gasket question
PostPosted: Sun Jan 28, 2007 2:42 pm
I'm having a brain fart here.
Do I use a silicone on the intake manifold or put it on dry?
I know the carb and the exhaust manifold go on dry, but can't recall about the intake.
The 2 silicones I have are orange and grey. They both say not for contact with gas, so I know I would need another kind if I am supposed to use any.
PostPosted: Sun Jan 28, 2007 3:17 pm
PITA Old Fart
Dry...always.
And unless it is sealing something in your engine that has coolant passing through it (like a water pump or thermostat)...don't use silicone.
Silicone doesn't work well around parts that come in contact with fuel or oil. It either doesn't seal or it pollutes the system.
PostPosted: Sun Jan 28, 2007 5:55 pm
8O Silicone was made to use in place of gaskets not with gaskets :?
PostPosted: Sun Jan 28, 2007 6:02 pm
tumwatertaz wrote:
Dry...always.
That intake has a port in it for coolant to go through, since the thermostat housing is in it, just make sure it cures for 24hr b4 you start it.
PostPosted: Sun Jan 28, 2007 7:42 pm
I have always used "the right stuff" black silicone on all gaskets of all engines I build (gas and diesel) except head gaskets. It is expensive but I like it and use it on race engines every day. I guess it is up to the builder but I can not stand leaks of any kind and with the right stuff I do not have them. I even used the stuff on engines I built working at every dealership I worked at.
PostPosted: Mon Jan 29, 2007 7:31 am
The front cover on my Buick motor is silicone only no gasket and still don't leak and i redid the motor in 86.Don't get me wrong there is a place for the stuff but to many people think that a little is good allot is better and that i have seen first hand rebuilding motors that some idiot used 1or even 2 shop size tubes putting the motor together.The problem most people don't see is silicone will stick to clean metal forever but will fall of a gasket then plug up the oil system.
