It is currently Wed May 27, 2026 12:14 am
 Post subject: I can't hit 55!!!!!!
PostPosted: Thu Jan 11, 2007 6:03 pm
Sorry for the song misquote but I really have a big problem here.
I have traded up to a 32/36 weber carb with a manual choke, I think I have the timing right. and the truck seems to run well enough but I can only make 55 on a level road and not much more. If I start going up hill I loose speed now matter how much I jam the pedal down. It's like the truck goes gutless all of sudden. I can run up to speed around 45-50 well enough and maintain them except on big hills.
What do you all think is the problem?
Thanks
Gareth
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Thu Jan 11, 2007 7:27 pm
How fast would it go with out the weber? sounds like my luv 4x4..LOL
PostPosted: Thu Jan 11, 2007 9:38 pm
Does the throttle linkage go full open with the pedal? I had that problem with the stock Hitachi carb at one time.
PostPosted: Fri Jan 12, 2007 10:57 am
most likely probrlem is the carb isnt getting wide open. Other than that i would check out the points and condensor, if they start going bad your truck will do that too...
PostPosted: Fri Jan 12, 2007 10:59 am
check the fuel filter too, mine did that when the filter was clogged.
PostPosted: Fri Jan 12, 2007 3:28 pm
In order of asking.
1. With the old carb 8 years ago and a engine rebuild later it would hit 70 and thats about it.
2.The linkage seems to be running all the way out at and the Butterflys open fully.
3. It is an 81 No points to my knowledge timing is set best to my abilty. I used a light gun but I could not determine the RPM like it is said in the manual. 800 RPM I think. I just guessed it by ear.
4. Fuel Filter could be an idea I changed it when I did the rebuild. and after having the gas tank cleaned. But not since then. 7 months ago.
PostPosted: Fri Jan 12, 2007 3:47 pm
You should always replace the fuel filter when installing a new carb.
Was the carb new or known to be good?
Might want to confirm adequete fuel delivery(pump rate & lines not blocked or kinked).
All vacuum lines capped that were eliminated with the weber?
Is the vacuum advance hooked up & functioning?
Just some thoughts
PostPosted: Fri Jan 12, 2007 6:58 pm
Does it have a cat underneath? When they get plugged up it will run great but with no power.
If it does have a cat, you can try going around the block with the exhaust disconnected and see what it does.
