It is currently Tue May 26, 2026 6:05 pm
 Post subject: carbs
PostPosted: Thu Mar 13, 2003 11:51 pm
what upgrade carb can i put on in a weekend with out n e mods that will add a little horse power to the stock 1.8. i don't need alot but just enough so i don't slow down going up this one hill around my town. thanx.matt
PostPosted: Fri Mar 14, 2003 12:18 am
weber 32/36 DGV type carb. It's concidered a direct replacement carb for the 1.8 motor. But it doesn't have provisions for emissions. It's a mechanical secondary carb that will provide additional power to the stock engine
PostPosted: Fri Mar 14, 2003 7:41 am
like blue meanie said. alot of guys here are using the weber :D . i need one.
PostPosted: Sun Mar 23, 2003 2:36 pm
i have a 380cfm webber and it works awsome. And you can even pass emisions whith alittle tweaking. And if you need a bit more power you can always put on spacers.
PostPosted: Sun Mar 23, 2003 5:12 pm
so if i added more spacres to the stock carb would that add some hp?
Users browsing this forum: No registered users and 67 guests
