It is currently Tue Jun 09, 2026 4:12 pm
 Post subject: engine temp
PostPosted: Thu Dec 21, 2006 3:20 am
have a 79 4x4 that Ineed to hook up the guage in the dash that shows temp ,what color are the wires where are the wires located underhood. thanks
 Post subject: temp sending under hood
PostPosted: Thu Dec 21, 2006 6:52 pm
the sending unit under the hood is under the intake manifold centered about midpoint between 1st and 2nd cylinders, about 2-3 inches from the engine. the "hot" wire from sending unit has a simple clip that hooks on the post of the sending unit. i think the wire itself is black or dark green, but I'm "slightly" colorblind. oh, well, that is the location on my '79 4x4.
give that a try. u might haf'ta look with a small mirror, if everything is in place under the hood. ...aft of the distributor.
PostPosted: Thu Dec 21, 2006 10:01 pm
It is sort of a slide on connector, and the wire should be black with a yellow stripe. The sensor is directly under the thermostat housing and feels a lot like the end of a bolt when looking for it by feel. The wire should come off the inner fender sort of near the coil and the wire that heads down to the distributor.
