It is currently Tue Jun 09, 2026 4:11 pm
PostPosted: Sun Dec 17, 2006 9:29 pm
Hey all, today was the first good day of driving my luv. (it just came back from the shop to get it runnin). It ran good for about 20-25 miles of driving time, and then, while hitting the brakes to stop at a stop sign, i leave a 200 yard line of white smoke. Also right before i stopped, the truck letout a pretty decent low 'pop' which sounded like a backfire.
So I drive it home and park it for about 2 hours. When i jump in it, it starts great, but now it 'pops' when the motor winds down during shifts, with a poor running acceleration. I don't know what to do. Thanks for any help, you guys. -Nick
Thanks, Nick.
PostPosted: Mon Dec 18, 2006 10:23 pm
Check for something simple like a vacuum leak. Spray some carb cleaner on gaskets and fittings to see if the idle changes.
PostPosted: Mon Dec 18, 2006 10:52 pm
White smoke usually means coolant, but yeah definatley check with carb cleaner, that usually will let you see which one is cracked or not on all the way.
-Austin
