It is currently Mon Jun 08, 2026 2:21 pm
 Post subject: Camshaft Duration?
PostPosted: Wed Dec 06, 2006 12:18 am
Im not sure what the duration is on a stock G180 camshaft and I found what looks to be a performance camshaft.
So is this a performance cam or an overpriced stocker?
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=HTC&mfrpartnumber=102601&parttype=146&ptset=A
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 06, 2006 6:37 am
Don't ask me, I couldn't tell you. I've been taking my work to Pacific Auto Machine shop in Renton, and they could tell you what you have. It's 4:30 in the morning and I'm writing posts in LUVTruck.com, so I can't call 'em for ya right now, but I'll make a note and stick it on my monitor!
Any good machine shop can explain the deal to you.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Wed Dec 06, 2006 3:54 pm
Ok sounds good.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 06, 2006 7:59 pm
I must have had my head somewhere else when I wrote about the camshaft. I still don't know, but now I'm thinking the duration probably means the degrees of camshaft rotation that the valve will be held open, or how wide the lobe is circumference-wise. Better let me ask that more directly to be sure, or perhaps some of y'all out there would elaborate?
I was focused on your price concern, and I looked around, as well as asked. I find that the price you had was not bad at all and I have found prices from $120 to $199. One thing to watch out for is high-performance camshafts usually will require a stronger set of valve springs.
Image Image
PostPosted: Thu Dec 07, 2006 12:10 am
I swapped in a 5 speed and since my truck used to be an automatic it has 4:10 gears in the rear end and the motor kinda lugs on the freeway. So Im looking to get a little more power out of it the cheapest way I can. I know what duration is on a camshaft I was actually wondering if this cam has more duration then the stock cam. I really didn't ask the question correctly sorry.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Dec 07, 2006 10:30 am
PITA Old Fart
Delta Camshafts would be a much better option...they will make you whatever cam you want from your stock cam pretty cheap and it doesn't take very long for them to get your cam done and back to you.
http://www.deltacam.com/index.php
They are in Tacoma,WA.
PostPosted: Thu Dec 07, 2006 11:24 am
There you go Dan. Thanks to LUVTruck.com & Tumwatertaz!
Image Image
PostPosted: Thu Dec 07, 2006 11:10 pm
lol I totally forgot about delta cams in Tacoma. I give them a call this weekend thanks for your help guys.
1975 V8 Luv
1980 Bagged Luv
