It is currently Sat Apr 11, 2026 7:26 pm
 Post subject: dash cap
PostPosted: Mon Nov 20, 2006 11:00 pm
Saw this while looking around the web. Thought some of you might be interested.....
They have them for all years
http://www.1aauto.com/1A/Dash_Pad_Cover ... zrate-feed
PostPosted: Mon Nov 20, 2006 11:06 pm
have been thinking about this. What if your dash is all curled up on top?
I dont think this would even help my situation.
I need a cap for the top, bottom, front and sides :lol:
78' LUV Mikado, Old
PostPosted: Mon Nov 20, 2006 11:13 pm
ctmandu wrote:
Michael Turnbull
DASHBOARD RESTORATIONS QLD PTY LTD
6/4 Lancashire Street
Acacia Ridge Qld 4110
AUSTRALIA
Ph 07 3273 5019
Fax 07 3273 4335
they dont have it listed but just email them
http://dashboardrestorations.com.au/
They Make Whole New Dashes....Cost A Pretty Penny
PostPosted: Mon Nov 20, 2006 11:17 pm
yeah its like 640 bucks
but i hear its worth it.
78' LUV Mikado, Old
PostPosted: Mon Nov 20, 2006 11:20 pm
It Tiz The Way I Am Probably Going To Go. Would Help Pull Off The "sleeper" Look
PostPosted: Tue Nov 21, 2006 7:05 am
Here's another look at mine. I ordered it from JCWhitney, and they got it from AccuForm, or some place like that. I'm going on memory now sitting at the keyboard, and I don't feel like going outside right now to get the papers. I left them in the LUV.
Anyway it cost me about $95. I think it's enough of a fix, but only time will tell.
Image Made in the USA
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Tue Nov 21, 2006 9:54 am
Mine has held up ok for the last 5 years or so. It has a faint crack from the passenger side vent along the crease towards the radio. It's not near enough of a problem to replace just yet. Concidering how bad my dash was to start with, it still looks pretty good.
A cloth cover across the dash pad to protect it would keep it from cracking for a good, long while.
PostPosted: Thu Nov 23, 2006 12:10 pm
do you have to chip away the old dash or does this just cover over the top of the old one. also how does it attach glue, velcro or????
thanks
Current Fleet
pics
PostPosted: Thu Nov 23, 2006 2:44 pm
The dash cap comes with a tube of adhesive. It's supposed to install over the exsisting dash top. Mine was so beat up that i had no choice but to remove the top of the dash and build a new foundation for the replacement dashtop. If you can get the original to lay flat instead of curling up along the split areas, it should work.
If you decide to remove the old dashtop and build a new foundation, i would recommened using thin sheets of cork. Cut pieces to fit, glue them in place with contact cement and then use the adhesive from the dashtop to fit the dash.
PostPosted: Thu Nov 23, 2006 3:13 pm
I had to cut out the existing dash along the base of the windshield. It was curled up as Meanie described. I saved a strip of the old foam and used the same clear silicone glue to attach it along the front-center of the cap for a foundation. There was also some curling up around the defroster ducts and I cut it away before the final placement of the dash cap.
Image Image
PostPosted: Thu Nov 23, 2006 4:34 pm
Banishment Pending
I have one in my truck and it's held up for about 12 years now
PostPosted: Thu Nov 23, 2006 6:38 pm
That's good news!
Mine went in real good. I hope it lasts a long time.
Image Image
Users browsing this forum: Bing [Bot] and 97 guests
