It is currently Tue Jun 09, 2026 12:21 pm
 Post subject: truck dead need help
PostPosted: Wed Nov 08, 2006 11:30 pm
ok my son was on the way home he said he heard a buss like the starter was spinning but not engaging and then the truck died , this was while he was driving down the freeway... he tries to start it and nothing but the buss.. motor not trying to turn over starter just spinning... my ? Is why would this kill the motor or what could have caused this to die and not start again?
he has fule pump working and all fuse checked
PostPosted: Wed Nov 08, 2006 11:54 pm
This sounds tough to figure out without seeing the truck. But im guessing that the starter solenoid has gone bad. And it's possible that the charging system couldn't keep up with the voltage loss. Not enough battery power means the ignition got weak to the point that it couldn't fire.
It sounds outragious but this is what im thinking.
Pull the starter and get it checked. Put the battery on a charger and see if it ran low. Tell us what you found out thus far.
PostPosted: Thu Nov 09, 2006 12:01 am
He will check tomorrow... I hope that the starter didn’t short and engage ripping off the teeth on the flywheel and that’s what he herd as a buzz,(he plays boom boom slap shit at full volume) at least that’s what we call his music when we teas him or...we say , hay you now rap is just crap with out the "C" :lol: :lol:
PostPosted: Thu Nov 09, 2006 4:05 am
could be some kind of short with the ignition switch itself. turned the starter on and the ignition off. just an idea. if he was cruizin down the freeway it probly did strip the teeth on something. hopefully just mucked up the teeth on your starter. probly didn't engage enough to strip the flywheel. we can hope :( good luck. :D
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Fri Nov 10, 2006 9:16 am
Maybe all the vibration from that rap crap shifted things over and now he has to learn his lesson that human ears were not meant for that kind of abuse!!
I hope you get it figured out and tell the forum what is was. I'm not too good with diagnosing sounds. With all the wiring complaints I read, it sounds like the ignition switch must have shorted.
Best of Luck...
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Sun Nov 12, 2006 4:28 pm
Well starter teeth and fly wheel ok so he is going to check the ignition and fuses, still no clue yet :?
Users browsing this forum: Baidu [Spider] and 36 guests
