It is currently Mon Jun 08, 2026 3:58 am
 Post subject: Enigne issues
PostPosted: Wed Oct 25, 2006 5:14 pm
As you know I have been working with my carburator for a while and I just got the float needle valve assembly replaced. It statrted running the other day and the next day it did'nt. So, I got a shop manual for my truck and it says multiple things that could be wrong. The carburator seems fine it just does not start. The starter cranks and it acts like it wants to start and I can try to keep it going but when let go of the throttle, it stops. If anyone can sell me a good carburator for cheap, maybe I can work soething out. I'm low on money and I am still in highschool. Thanks for the help.
PostPosted: Wed Oct 25, 2006 10:06 pm
what year is the truck???
PostPosted: Sat Oct 28, 2006 7:17 pm
It is a 1980
 Post subject: engine
PostPosted: Sat Oct 28, 2006 7:33 pm
Try capping off all the vacuum ports on the carb and intake manifold except the spark advance and then try starting and see what happens
 Post subject: Re: engine
PostPosted: Sun Oct 29, 2006 1:14 pm
What happens when I cap them off. There are already some of the hoses at the bottom of the carburator are plugged with screws and I don't know where they go.
PostPosted: Sun Oct 29, 2006 3:46 pm
heres how the vacuum lines should look if you bypass everything.
this one i'm pointing at a broken fitting you can plug off and the line to the right of it goes to your vacuum advance.
hope that helps ya
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
