It is currently Mon Jun 08, 2026 8:30 am
 Post subject: rear end question
PostPosted: Fri Jul 28, 2006 10:50 am
I know this goes in the 4x4 section but I thought I'd get a quicker responce if I posted here. Will a 81 luv 4x4 rearend be the same as a 80 4x4? same gears and brakes? mounting locations? Thanks. Christopher
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Fri Jul 28, 2006 10:56 am
well in short... i think so. those years have the same gear ratio and i don't think the mounting hardware ever changed. check this post http://forums.luvtruck.com/viewtopic.php?t=11013
1980 luv 1.8 finally running!!!...... and then like a moron i sold it :(
got another one!!! 1980 mikado. v8 swap here we come... nope divorce and cross country move happened.
got another one!!! 1980 4x4 mikado sport. rusty beater for now...
PostPosted: Fri Jul 28, 2006 3:20 pm
Gear ratio and mounting should be the same, but the brakes are different. They changed the rear brake shoes around some in 81. That should not prevent you from using it though, just have to remember to buy brake shoes/parts for an 81 if you ever do the brakes on it. The only thing I'm not totally sure of is if the e-brake cables would be the same, but I am thinking that they'd fit.
Users browsing this forum: Bing [Bot] and 18 guests
