It is currently Tue Jun 09, 2026 1:33 pm
 Post subject: Got Slop?
PostPosted: Fri Jul 07, 2006 1:13 pm
I do and I want to fix it ( in my steering I have major play) cant I adjust something
 Post subject: Slop
PostPosted: Fri Jul 07, 2006 1:44 pm
Depends where the slop originates. The steering gear box at the bottom of the steering column is adjustable with a big slotted screw with a locknut around it. If the tierod ends or ball joints are worn, then a replacement is called for.
PostPosted: Sat Jul 08, 2006 5:02 am
The easiest way to find where your slop comes from is to have someone turn the steering wheel back and forth while you watch things under the truck. Get them to turn it just far enough back and forth to make the tires move just a smidge, then look at the whole steering system starting at the box. Look for something that is moving a bunch before the tires even begin to wiggle.
PostPosted: Sat Jul 08, 2006 7:52 pm
I put my hand on the different joints to feel for slop while my son rocked the wheel. On mine I found a sloppy idler arm.
I remember reading that they are not available any more. Am I screwed? I want a new one if possible rather than used.
PostPosted: Sat Jul 08, 2006 8:12 pm
Ron, it depends on what is bad on your idler arm. Rock auto has a idler arm bushing kit for 20 bucks or so.
