 Post subject: kind of a dumb question
PostPosted: Tue May 30, 2006 12:56 pm
what year of motor (G180) are the intake and exhaust on the same side?
PostPosted: Tue May 30, 2006 3:20 pm
72 - 75. Correct me if I'm wrong, but I'm pretty sure that 75 was the last year.
PostPosted: Tue May 30, 2006 9:06 pm
next question are the heads interchangable between that motor and the later model motor?
PostPosted: Tue May 30, 2006 10:03 pm
72-75 has the early isuzu motor
76-87 the Gxxx serise motor was used.
there are no interchangable parts between the different motors.
PostPosted: Tue May 30, 2006 11:44 pm
All the above (72-75) is right, at least in the US market. I don't know when the early style LUV motor was first used by Isuzu elsewhere, or if they kept using them somewhere overseas. Both of them say G180 on them, just to make that point clear. It was nice of them to confuse things like that.
Other than maybe some nuts and bolts (I think head bolts are actually just about the same) no parts swap over on the two motors.
PostPosted: Tue May 30, 2006 11:47 pm
i dont understand what your sayin here. the head from the early motor will fit on a later motor? ive looked at a early motor and the block and the head are sompletely different than a later motor. im confused...???!?!?!
OHHHHH!!!
i didnt comprehend what you said. never mind this post.
PostPosted: Wed May 31, 2006 10:06 am
No He said just the head BOLTS might interchange.
PostPosted: Wed May 31, 2006 3:13 pm
Yeah, just the bolts. Sorry. That sentance I wrote is a bit confusing. I use way too many parenthesis () when I write. The heads are very different and would not interchange.
