PostPosted: Fri May 12, 2006 2:12 pm
my stock exhaust manfold cracked and i want to find something to replace it but cant find anything available so i want to find the 76 or newer motor and a put a 5spd tranny in at the same time any suggestions need some help please its my means of transportation and have no clue what i am looking for
PostPosted: Fri May 12, 2006 7:04 pm
the classifieds section will have give you a better idea of price and availablility of what you are looking for.
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Fri May 12, 2006 9:46 pm
I will know Sunday if the header I have for sale is sold or not. I will pm you on Sunday afternoon.
PostPosted: Fri May 12, 2006 10:29 pm
where are you from? the yard here has a good motor but no 5-speed
PostPosted: Wed May 17, 2006 11:12 pm
I keep hearing the 2wd drive conversion for a 5 speed is much easier than the doing 4wd.
I think the only major modification is to shorten the drive shaft.
PostPosted: Thu May 18, 2006 12:04 am
how you are i have a 5 speed and disc rear end out of an 89 pup.what year do you have
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu May 18, 2006 12:36 am
With the right 5Spd, even the driveshaft length isn't an issue. You do need to have the right yoke with the correct spline count. A 76 has a coarser spline than the 5spds I've looked at. The 5 spds match a TH350 and I believe the 4x4 LUV though.
I have not had a chance to measure a 2WD Isuzu PUP 5 spd, but the one from my 88 Impulse parts donor is the same length as one I pulled from a 76 LUV. It is also set up for a hydro clutch where the PUPs were setup for a cable.
PostPosted: Thu May 18, 2006 5:16 pm
800xl wrote:
That's good to know. The 76 auto tranny also matches the th350...
Resident lurker
PostPosted: Thu May 18, 2006 11:13 pm
the one i got is not cable it is hydo and the stater is on the pasnger side
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Fri May 19, 2006 4:40 pm
if you are referring to xl's post, you are saying the same thing about the clutch... bikes truck is hydro, pup was cable.
What do you mean about the starter? All the 72-75 luvs had starters on the pass side...
Resident lurker
