PostPosted: Tue Apr 11, 2006 2:15 pm
How many quarts of oil does a 80 luv 4x4 hold? I thought it was 5.3 quarts but I am verry unsure. my dipstick reads way over the line and i dont want to blow anything so, do I have too much oil in it? Thanks yall!
80 luv 4x4, 2-1/2" torsion lift, 31x10.5/r15, 3" body lift, soon rear shackle lift.
85 monte carlo, goodwrench 350, cam, headders, intake, U know... the works.
PostPosted: Tue Apr 11, 2006 4:54 pm
I think I usually end up with 4 quarts and a little more for a full oil change with filter. There is some oil that stays up in the head, and probably other areas of the engine to make up the extra quart quoted in the specs.
When I do an oil change, I dump in 4 quarts, give it a few minutes to settle, then check the stick to see how much more to add. Don't believe the quoted specs. A good ding in the oil pan will lower the capacity, and a fair number of vehicles around have some dings in their pan ;)
As for having too much, well that is a debate I guess. If your truck drinks a lot of oil like my old 79 did, it might not take it long to get back down to normal. I would try to figure some way to get some out of it if it is way over the line. Get a siphon pump with a small enough pickup tube to get down the dipstick tube and pull some out. The hash marked section of the dipstick is about a quart wide (one quart will go from the bottom of the stick to the top of the hash marks) so that gives you some idea of how much too much you have in there.
PostPosted: Tue Apr 11, 2006 5:03 pm
Great. I just noticed that I have a little black liquid stuff coming out of my tail pipe, so that is why I thought I had too much oil. my luck its the head gasket.
PostPosted: Tue Apr 11, 2006 10:44 pm
just one (q) you do have the right dip stick i my self got my luv 75 and it had the rong stick in it so if you do got the right one then go to the thred you dip stick that might help i hope soo
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Apr 12, 2006 10:35 am
when i change my oil i usually put in 4.5q run it for a few minuets then have to add another .5q. That black fluid coming out your tail pipe is probly just water. My truck gets that every now and then if it sits for more than a day or so. Water will condense in your muffler and exsaust pipe and will mix with carbon from the exsaust and then get blown out. Perty common for high humidity areas like ours!
PostPosted: Wed Apr 12, 2006 10:44 am
sweet! I dumped a quart out last night and its still over the hash marks. I ran my truck 4 a while and it sounds fine so im gonna drive it like this for a few to see what happens.
PostPosted: Thu Apr 13, 2006 5:37 pm
I usually start with mine 1/2 quart high. That way, as it uses it, it never gets too low. Doing it this way, I use 5 quarts for an oil change. (Funny how I never seem to drain 5 quarts out though.)
If you put way too much oil in, it will make the engine smoke. Assuming it doesn't go crunch, you can take some out and the smoke will clear.
You went there in that?!?!
PostPosted: Thu Apr 13, 2006 6:29 pm
I forgot to mention, you should also recheck after you've run it when you do an oil/filter change. If you put on the filter empty it will suck some of it up. I have gotten into the habit now of filling up the filter before I put it on.
PostPosted: Thu Apr 13, 2006 8:46 pm
80luv4x4stock wrote:
...my dipstick reads way over the line ....
Are you checkin' it while it's running? I would think somewhere over 4.5 qts should do for a 1.8, I kno a 2.2 in s-10's and cavaliers take 4 qts, but ecotec 2.2s take 4.75, IDK, never actually drivin a gas luv... am I missing out? lol
PostPosted: Tue Apr 18, 2006 11:35 pm
oil change today, and I added 4 quarts and its rite on the line but the motor sounds like the main rod's are about to go... my carb is fucked! it runs but I have no power. The tranny whine's loud and NO POWER IN 3RD GEAR. lol but it runs awsome other than that!!! :n00b:
PostPosted: Wed Apr 19, 2006 8:49 am
if you have the 4x4 oil pan it takes 5 qts if you have the 2 wheel drive oilpan it is 4.5
PostPosted: Wed Apr 19, 2006 11:12 am
I do have a 4x4 and i just did another oil change and only put in 4 quarts and its rite on the line. My motor still runs like crap and has no power in 3rd and 4th gear, but hey... it runs! I just moved a couch and it went fine! just a little slow! I guess I should not go by the book? the book say'd 5.3 quarts.
PostPosted: Thu Apr 20, 2006 1:19 am
PITA Old Fart
What type of oil did you put in it?
I always use Castrol 20/50 in my stocker 2wd's and they run like a scalded dog.
PostPosted: Thu Apr 20, 2006 1:46 am
oops sorry i have a 2.6 now not a 1.8
PostPosted: Thu Apr 20, 2006 8:52 am
Me? I used castarol 10w-30. I used the same before exept I put in a quart of hyperlube. I have been driving all over Everett and it seems to be going ok. Im driving it to go move some stuff today. I think if I got a better carb and installed my MSD ignition then I would have ALOT more power. What is the plug gap supposed to be at? and what is the plug gap supposed to be with a MSD?
