It is currently Mon Jun 08, 2026 10:50 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Mar 04, 2006 6:01 pm
My gauge goes right all the way to hot as soon as my ignition is turned on. Does that mean mine works?
PostPosted: Sat Mar 04, 2006 7:42 pm
800xl wrote:
I found a picture online of what it looks like out of the intake. The end on the left of this picture that looks like the head of a nail is the part that sticks out the bottom of the intake. It is directly under the thermstat housing where the top rad hose goes into the intake. Your picture does look like the right connector, it should slide on over the tip of the sender from the side.
Here is the pic:
This is one of the hardest things to find at first so don't feel too bad. You really have to dig in and look for it though, even with the best instructions this is one you'll have to work for.
Where did you find that photo. I need one, I bought one but it was too big.
PostPosted: Sat Mar 04, 2006 8:14 pm
Chavy, you really need to get a manual and read up on this temp deal. The manual will walk you through it. If you can not figure it out, you might be over your head and need to visit a mechanic.
PostPosted: Sat Mar 04, 2006 8:48 pm
I don't know why I am doing this.
Now Chavy, what I am about to tell you I just did. I walked out to my garage and did a simple test and walked back into my house in under 3 minutes.
Here is a simple test:::::
Between your battery and ignition coil there is a white plug connecter with 4 wires. At the engine side of the wiring harness you will see a wire that is yellow with a black stripe on it. The connector should fit over the nail head. Now run a wire from the negative side of the battery to the yellow with a black stripe wire. Go into the cab of your truck and turn the ignition to on. The stock temp gauge should go to the H side. Now walk out to the jumper wire and remove it and the gauge should go down to the C side of the gauge. If it does, then all of the componets work for the stock gauge and you need to install the new temp sending unit in the manifold and hook up the wire and you are done.
We don't mind helping out here but you need to know the basics and have a manual.
PostPosted: Sat Mar 04, 2006 8:53 pm
Ben wrote:
Plug the wire into the "nail" on the sensor and hold the outside of the sensor against some unpainted metal on the truck while someone watches the gage. It should move slowly up to the "C".
My bad, I assumed that "C" was not the end of the needle travel without looking first.
PostPosted: Sat Mar 04, 2006 9:37 pm
i have a manuel and dose not have a dam thing on the intake or the sending unit
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sun Mar 05, 2006 10:37 am
Ok. We have now given you two or three different ways to diagnose your problem / question. You need to try one of them, and let us know what you find out.
Luvrv8 really spelled it out for you. If I was you I would print up his post and go out to my truck and do what it says, before I posted anything else. :wink:
PostPosted: Mon Mar 06, 2006 11:58 pm
Japanese Redneck
LOL.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Mar 07, 2006 1:47 am
just a question fellas, where should the needle on the temp gauge sit when driving at operating temp? theres a white section in the middle, mine sits just below that
PostPosted: Tue Mar 07, 2006 4:08 am
Mine too.
PostPosted: Tue Mar 07, 2006 8:28 pm
Mine sets just about flat across when up to temp. Somewhere near the middle of the white area. Could be you have no thermostat or it is stuck open.
PostPosted: Tue Mar 07, 2006 11:25 pm
Mine sits at the top of the white on mine. 8O I hope its just the different sending unit I have on it cause its off of a Ford FE. But if its correct how hot would that be?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Mar 08, 2006 1:12 pm
Just noticed your earlier post, pic is from http://www.rockauto.com, do a search for "rockauto code" for a discount thing I posted not long back, I think it should still be good.
PostPosted: Wed Mar 08, 2006 7:29 pm
Thanks I just ordered one, hopefully it's the right one this time.
PostPosted: Thu Mar 09, 2006 9:38 pm
After all of the work we did to help you Chavy, we demand some sort of result.
PostPosted: Thu Mar 09, 2006 9:55 pm
ok the wiring is still good I put of geting the sending unit but ever thing is a go
79 4x4 1.8 liter
PostPosted: Fri Mar 10, 2006 4:53 pm
mine used to sit right in between that break in the white lines about an inch past the C before I had all sorts of overheating problems (see http://forums.luvtruck.com/viewtopic.php?t=9783 ) Does anyone know the approximate temperatures that the needle points to on a stock gauge? I am guessing that break in the lines I described is about 180/185 degrees (thermostat is rated there). what is it at when it reaches the end of the white lines (the gap before the H)? How about the H itself?
PostPosted: Fri Mar 10, 2006 6:54 pm
My guess would be that they are all very different from each other. especially now that they are 20-30 years old.
PostPosted: Fri Mar 10, 2006 8:39 pm
Yep, Mine is really different, it sits a 0 until started. Actually it is reading 71 but it was running when I took the pic. :roll:
 Post subject: new dash
PostPosted: Sat Mar 11, 2006 2:07 am
you know where to get a new dash pad if so let me know please thanks
dangerous-toys4life
75 k-5 2x
94 king cab
