It is currently Mon Jun 08, 2026 6:59 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 18, 2008 11:17 pm
Hay, TJ White --- You're my neighbor! I live a couple towns over in Pilot Rock! We'll have to set up a Chevy LUV gathering or sumthin'! :P
I don't need any extra parts (that I know of yet), but I will be looking for a weber 32/36 pretty soon to boost the HP. I gotta let the savings account build back up first --- which may take a few millennia.....or a couple months, whichever comes first.
Anyway, I'm gonna start a new thread in the 'Introductions' section and post a couple PICs! See ya there!
PostPosted: Wed Jan 23, 2008 6:18 pm
haymanmarc wrote:
boost the HP.
Keep your eye out for a cheap any other RWD Isuzu 4cyl.
Impulse or a later pickup or trooper II.
2L turbo
2.3L carby motor.
2.6L EFI motor.
If you can follow a firing diagram 2.6L EFI makes a big difference. Time better spent than putting a weber on a G180
Bob.
PostPosted: Wed Jan 23, 2008 6:42 pm
buy a 350
PostPosted: Wed Jan 23, 2008 6:58 pm
ugotluv wrote:
buy a 350
to use as an anchor for your boat. :wink:
Bob
PostPosted: Thu Jan 24, 2008 5:07 pm
hay bob....
are those 2.__ liters v6's or 4 bangers? I kinda feel like the v6 is the way to go, but what do i know? I'm new to these...
Seems like a v8 would be overkill.... :lol:
Anyway... so far I've checked the plugs. The first plug closest to the back of the engine had a bit of a gasoline smell to it. The gaps on all were close, but a little wide so I corrected them. I checked the fuses and discovered 2 bad.
I pulled the dist cap and didn't see any points. Does the 78 have points? I saw a condenser...
Next, I'll check the timing/dwell. Then spray out the carb -- try to clean it up a bit. If that doesn't do enough, then I suppose I'll pull the carb and check the float. If that's not enough then throw a kit on it and rebuild it.
what do you think?
PostPosted: Thu Jan 24, 2008 7:29 pm
They are both 4cyl and are pretty much a bolt in fit with the right mounting hardware.
See these two threads.
http://forums.luvtruck.com/viewtopic.php?t=15982
To make the 2.6L a carby motor.
http://forums.luvtruck.com/viewtopic.php?t=15987
Im not 100% sure but the 2.6L motor was near on 100kw with a balls load of torque for a 4cyl. The 2.3L wasnt far behind it 89kw or something springs to mind. (when they dropped our local Kingswood ute in 84 all you could get from GM was a 2.3L (Rodeo) pickup and it had more go than the 3.3L straight six in the old ute. Ive got a write up here from a motor mag, a test of 4 utes 2 jap the 2.3L pickup and our local Ford Falcon ute with a 250cid inline 6cyl. The pickup came out the winner after various tests loaded/empty and economy.)
Bob.
Users browsing this forum: No registered users and 50 guests
