It is currently Mon Jun 08, 2026 9:59 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 28, 2006 4:05 pm
Hey Blue Meanie, thanks for the link. I should have looked at Grants webpage to begin with. duh! haha.
But you have inspried my new signature:
"When all else fails, follow the directions"
PostPosted: Sun May 28, 2006 5:47 pm
I think I'll have to make a trip to the junkyard, I think the part that
touches the back of the adapter is broken off.
Also I believe that the wire off the plastic ring goes through the extra hole and there is a point to where you can soder on the wre on the back of the adapater.
PostPosted: Mon May 29, 2006 2:59 pm
There should be a spring loaded button sticking out of that piece about 1/2 inch or so that rubs the ring on the bottom side of the adapter. It is not something you can really replace on its own very easy though. You pretty much have to take the whole turn signal switch assembly.
If memory serves correctly you have the other part figured out. I think that wire is just soldered to the ring on the adapter.
PostPosted: Mon May 29, 2006 10:05 pm
Yea, I think my button broke off, It was not working when I first got the truck.
Although the good news, is that once you have the wheel and the plastic column case off, there are 2 phillps screws and the whole turn singal assembly should just pop off.
PostPosted: Tue May 30, 2006 12:25 am
Yeah it is easy to pull. Getting the wiring unplugged from the harness is harder than getting the switch loose usually.
PostPosted: Thu Jun 08, 2006 10:57 am
this it how i did mine
http://s71.photobucket.com/albums/i158/ ... 0_0518.jpg [/img]
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
