It is currently Sun Jun 07, 2026 5:21 am
 Post subject: Three stupid questions
PostPosted: Sat Mar 22, 2003 8:24 am
First of, if the idiot that built my luvette would have knew what he was doing i'd already know this, but since he didnt I gotta ask.
1. Did the 80 LUV come with a cat. converter?
2. What are the wires sticking out of my t-case and 4 speed transmission?,Speedometer and RPM wires?
3. If so where can I get the guages, and wiring I need to hook these up?
PostPosted: Sat Mar 22, 2003 8:43 am
not that i know of. :?
PostPosted: Sat Mar 22, 2003 12:27 pm
Hey 4x4,
One wire is for the 4x4 light, One is for the reverse lights, One is a ground.
My 81 HAD a cat conv( for about 20 min) but don't know bout an 80?
BTW you have mail.
Dave
PostPosted: Sat Mar 22, 2003 2:52 pm
never thought of the lights.... so, where does the speedometer cable go, i've looked all over this thing and I sure a sheck aint found it yet.
What does would it take to hook the backing lights up?
PostPosted: Sat Mar 22, 2003 5:26 pm
My '76 had a catalytic convertor so I assume an '80 would. Of course, back then it also depended upon what State your vehicle was intented for.
PostPosted: Sun Mar 23, 2003 2:19 pm
well unless its a cali. truck it wont have a cat. My 80 just had the air pump on it. The wires out of the tranny are for your back-up. On the t-case its your 4x4 light. Im perty shure the speedo cable goes to the rear end. Ill look up in my service amnuals next time i have a chance.
PostPosted: Sun Mar 23, 2003 4:43 pm
ok thanks, i'll hafta check the rear end now I guess, and try to rig up a cable long enought o hook it up...
PostPosted: Mon Mar 24, 2003 12:00 am
My 75 is not a cali truck and it had a cat. Here in Oklahoma anything 79 and newer has to have the cat and we're pretty easy on the emissions stuff.
PostPosted: Mon Mar 24, 2003 6:18 am
the speedo cable should go into the tranny on the driver side close to the rear......
03Cobra
PostPosted: Mon Mar 24, 2003 8:03 am
My 80 4x4 had a converter but i cut it off!!
PostPosted: Mon Mar 24, 2003 5:34 pm
FOUND THE PLACE FOR THE SPEEDOCABLE, its near the bottom on the right back side of the t-case
 Post subject: catalitic converter
PostPosted: Mon Mar 24, 2003 6:44 pm
My 80 does not have a catalitic converter on it. The label under the hood said "NON CATALIST".
Funny thing is the GOODYEAR Dealer would not pass it for inspection because it didn't have a converter on it.
1980 4X4 LUV
PostPosted: Mon Mar 24, 2003 11:08 pm
well my luv was odered by my dad to go to WA state so its a bit diferent and it had no cat. :?
PostPosted: Wed Mar 26, 2003 7:03 am
My 79 4x4 dosent have one either.I pass Tx. inspections,...
PostPosted: Wed Mar 26, 2003 11:49 am
Pre-1984 vehicles in TX do not require a cat conv. Just in case anyone needs to know.
PostPosted: Thu Mar 27, 2003 7:19 am
Good, thats nice to know! Im glad i cut the one off my 80.
