It is currently Sun Jun 07, 2026 6:48 am
PostPosted: Tue Mar 04, 2003 9:42 pm
my problem was between a carb and points, Luv runs great now!!!! 8)
PostPosted: Wed Mar 05, 2003 12:10 am
The fuel lines directly on the carbeurator, where the gas enters and returns, is what you need to remove. Save that little gasket!!!!
The needle and seat is the little valve that lets the gas into the carb, and returns the excess back to the fuel tank. (Am I right, guys?!??) If you remove that part from the carbeurator, it almost looks like a little spark plug, but it opens and closes. Just blow it off with compressed air and make sure it's clean.
Hope it helps.
PostPosted: Wed Mar 19, 2003 7:36 pm
Well, the alternator was putting only slightly more than 10 volts, so I've replaced the alternator. Under lifetime warranty, no charge. Then I replaced the battery, total prorated cost was $18.99. Then I got an actual Japanese voltage regulator for $17.05. (I'm not going to include the $85 I blew on a fuel pump that I now realize I didn't need--but then an education is not free.)
The result? It no longer dies on the road. The cutting out on the road began the day after I drove 160 miles with a washer and dryer in the back, taking close to 5 hours for the trip. It rained most of the way. So I had on my lights, wipers, occasionally the heater for defrost. And of course the radio.
So I'm presuming that this electrical load on the undercharging system is what caused the immediate problem to become apparent. Anyhow, it doesn't cut out under speed now.
But it still cuts out at traffic lights and stop signs. I'm going to go over the carburetor next. And maybe redo the recent tune-up. Weather and work have kept me from it so far but maybe this Friday and Saturday.
And if that's not it, then who knows? Maybe the fuel pump relay after all, maybe a solenoid.
But at least I'm driving again.
Lessons: If it's cutting out, check your battery. If that's low, check your alternator. If you change your alternator, it's recommended that you also change your voltage regulator.
Thanks, big-time, for the help, guys. When I get it completely fixed, I'll post what it was. Cordially, cl.
PostPosted: Wed Mar 19, 2003 10:25 pm
......sorry... posted in thr wrong place.
